This mode cannot be used with jobs without a job ticket.
This mode is available for the job with a job ticket which the perfect binding mode is already set.
The Perfect Binding mode can be set only if the Perfect Binder-D1 is attached.
Be sure to correctly set the paper type. If the type of paper is not set correctly, especially when you use special types of paper, such as heavy paper, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
Before performing perfect binding, we recommend you to check the curl state of a using paper type. You need to print out the main document and a cover to the finisher or stacker, and check that curl is within the following specified value.
![]() *1 Height of Curl: Less than + 3/8" (10 mm)
*2 Height of Curl: Less than - 3/8" (10 mm)
*3 Length of Curl: More than 1 15/16" (50 mm)
If you use the paper type that curls easily exceeding the specified value for perfect binding, the following problems may occur:
The finishing size of output is different from the specified one.
Paper jam occurs.
Error occurs.
On the Job Hold screen, you can only confirm and adjust such the settings as shown in the table below. To change overall settings, store the file to a Mail Box and specify settings again.
(Main Menu) → [Hold].
If you press [Cancel Settings], settings which are already specified for the job are canceled, and you cannot change the settings in the Job Hold screen.
[Left Opening]:
A booklet that opens to the left is created.
[Right Opening]:
A booklet that opens to the right is created.
If you enter a value other than 0, you can switch between the positive and negative adjustment amount by pressing [±].
If the amount of the trimming is between 1/4" to 2" (6.0 mm to 50.0 mm), each setting can be applied.
