Hold Job List
Jobs stored in the Hold Queue are displayed. |
Update
Press to check whether paper required for the job selected from the Hold Job List is loaded into the specified paper source. This button is activated if you select a job without a job ticket. You can check the paper information only for jobs in the Hold Job List. Jobs in the Print Job List cannot be checked with this button.
If the specified paper source runs out, (
![]() ![]() In these cases, perform one of the following operations, and then press [Update] to refresh the list.
Load appropriate paper.
Select another paper source. (See "Specifying a Different Paper Source (Change Paper) .")
Load appropriate paper and register the paper information. (See "Registering the Paper Size and Type for a Paper Source.")
Display All Users/Show Only Sel. Users
Press to select the jobs to display based on the user name. You can display the jobs under all user names or only those under specified users.
4.
Details/Edit(Hold Job List)
Press to display [Print Sample], [Details], [Preview], [Move/Dup. to Mail Box], [Delete], and [Chg. Paper]. |
5.
Select All (Max 100)/Clear Selection
Press to select all of the jobs in the Hold Job List, or to clear all of the selected jobs.
6.
Delete After Print
Press to delete a job automatically after printing is complete. |
7.
Start Printing
Press to start printing a selected job. |
8.
Details/Edit(Print Job List)
Press to display [Priority Print], [Details], and [Pause Printing]. |
9.
Cancel
Press to stop a selected processing job. |
10.
Print Job List
The job that is currently printing and jobs that are waiting to print are displayed. |
Hold Job Details/Edit Screen (with Job Ticket)
Hold Job Details/Edit Screen (without Job Ticket)
Edit/Confirm Job Ticket
Press to edit/confirm the job ticket of a selected job.(See "Job Hold Function.")
This button is activated only if the selected job has a job ticket. Jobs submitted from the printer driver do not have a job ticket.
Details
Press to dislay the detailed information for a job or to change the name of a job. (See "Checking a Job's Detailed Information.") |
4.
5.
Press to move selected jobs into a mail box, or to make duplicates. (See "Moving/Duplicating a Job into the Mail Box.") |
6.
Delete
Press to delete a selected job |
7.
Change Paper
Press to change the paper source of a selected job to another paper source. (See "Specifying a Different Paper Source (Change Paper) .")
[Change Paper] is only valid when a job without Job Ticket is selected.
Pause Printing
Press to temporarily stop all processing print jobs.
Details
Press [Pause] to temporarily stop the job. Press [Paper Feed] to forcibly print the print data remaining in the memory. Press [Skip Error] to temporarily disable errors and continue printing. For information on the errors that can be temporarily disabled by pressing [Skip Error] after you select a job, see "Printer (List of Error Messages)." |
4.
Cancel
