e-Manual
Top
Site map
Help
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products
Software
Settings/Registration
Paper Type Management
Adjustment for Image Quality and Finishing (Calibration)
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
How to Use This Manual
Expand All
Collapse All
Category Top
Job Hold Function
Hold Screen
Storing Documents in the Hold Queue
Printing Files Stored in the Hold Queue
Canceling a Job
Specifying a Different Paper Source (Change Paper)
Sample Print
Arranging Files Stored in the Hold Queue
Priority Printing
Changing the Number of Copies of a Job
Collating Prints
Page Numbering
Adding a Cover
Inserting Sheets
Booklet Mode
Perfect Binding
Editing the Settings of Each Partition
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Optional Products
Software
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Hold
Priority Printing
Priority Printing
0L3X-192
You can change the printing priority of a job, so that it is printed right after the current job is complete.
Press
(Main Menu) → [Hold].
Select the desired job from the Print Job List → press [Details/Edit] → [Priority Print].
Back to Top
