The Finishing modes cannot be used with jobs without a job ticket.
Be sure to correctly set the paper type. If the type of paper is not set correctly, especially when you use special types of paper, such as heavy paper, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
If you set the Staple, Hole Punch, or Z-Fold mode, the side of the paper which is printed on will always be output face down.
If you select [Stacker], you can change the output destination for each job to either [Stack Area] or [Output Tray].
When the Output Destination Is Set to the Finisher
When the Output Destination is set to the Stack Area of the Stacker
The paper used for the cover page must be the same size as that which is used for the main document.
If you load preprinted paper to use as the cover page into the document insertion unit, you must load the paper face up.
The following shows the paper weight that you can use when the Saddle Saddle Finisher-AM2 is attached.
For the cover page and main document: 52 g/m2 to 300 g/m2 (14 lb bond to 110 lb cover)
The following shows the paper weight that you can use when the Booklet Finisher-T1 is attached.
For the main document: 60 g/m2 to 220 g/m2 (16 lb bond to 80 lb cover)
For the cover page: 60 g/m2 to 256 g/m2 (16 lb bond to 140 lb index)
The [Saddle Stitch] mode can be set only if 2-Sided Printing is set.
The accuracy of folds created in the Saddle Stitch mode may vary, depending on the paper type and the number of sheets.
The Trim mode can be set if the Booklet Trimmer-D1 or the Two-Knife Booklet Trimmer-A1 is attached to the Saddle Finisher-AM2.
[Auto]:
If you are printing a single page original, the printed sheets are output face up. Otherwise, the printed sheets are output face down.
[Face Down (Normal Order)]:
Printed sheets are always output face down.
[Face Up (Reverse Order)]:
Printed sheets are always output face up.
You can set [Trim] only if you select [Saddle Stitch].
If both the Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1 are attached, you can select the fore-edge trimming individually.
The Saddle Press mode is set automatically when you select [Saddle Stitch].
To make sure that the [Saddle Press] setting is effective, you must saddle stitch more than nine sheets of paper (including one cover sheet).
Optional Unit
Collate (Page Order)
Group (Same Pages)
Offset
Staple
Hole Punch*2
Multiple Hole Punch*2
Fold*2
Trim
Face Up/Face Down
Saddle Press
Corner
Double
Saddle Stitch
Saddle Fold
Z-Fold, C-Fold, Half Fold, Accordion Z-Fold, Double Parallel Fold
Fore Edges of Booklet
Top/Bottom of Booklet
None
Output Tray-A1
Finisher-AM1
Finisher-AM1 and Puncher Unit
Finisher-AM1, Professional Puncher-B1, and Professional Puncher Integration Unit-C1
Finisher-AM1 and Paper Folding Unit-F1
Saddle Finisher-AM2
Saddle Finisher-AM2 and Puncher Unit
Saddle Finisher-AM2, Professional Puncher-B1, and Professional Puncher Integration Unit-C1
Saddle Finisher-AM2 and Paper Folding Unit-F1
Saddle Finisher-AM2 and Booklet Trimmer-D1
Saddle Finisher-AM2, Booklet Trimmer-D1, and Two-Knife Booklet Trimmer-A1
High Capacity Stacker-G1
Staple Finisher-T1
Staple Finisher-T1, and External Hole Puncher
Booklet Finisher-T1
Booklet Finisher-T1 and External Hole Puncher
Paper Size
Corner
Double
Saddle Stitch*
13" x 19"
25 sheets
12 5/8" x 17 11/16"
25 sheets
12" x 18"
25 sheets
11" x 17"
50 sheets
50 sheets
25 sheets
LGL
50 sheets
50 sheets
25 sheets
LTRR
50 sheets
50 sheets
25 sheets
LTR
100 sheets
100 sheets
EXEC
100 sheets
100 sheets
STMTR
STMT
Paper Size
Corner
Double
Saddle Stitch*1
305 x 457 mm (12" x 18")
16 sheets
SRA3 (12 5/8" x 17 11/16")
A3
30 sheets
30 sheets
16 sheets
B4
30 sheets
30 sheets
16 sheets
A4R
30 sheets
30 sheets
16 sheets
A4
50 sheets
50 sheets
B5R
B5
50 sheets
50 sheets
A5R
A5
11" x 17"
30 sheets
30 sheets
16 sheets
LGL
30 sheets
30 sheets
16 sheets
LTRR
30 sheets
30 sheets
16 sheets
LTR
50 sheets
50 sheets
EXEC
50 sheets
50 sheets
STMTR
STMT
For information on the original orientation and paper orientation when performing stapling, see "Relationship Between the Original Orientation and Paper Orientation."
For information on optional products that can be used with this machine, see the following:
You can display the detailed information of the selected paper by pressing [Details].
