      0WR6-0RS
      When an Error Message Appears
      If an error occurs during scanning or printing, or if a problem occurs with the network connection or settings, a message appears on the machine display or the Remote UI screen. For details about each message and solutions to the problems, refer to the messages below.
      The Active Directory site information is invalid. Contact the system manager.
      Could not verify CRL.
      FM DL SIZE ERROR n
      FM DL SCALE ERROR n
      FM DL FONT MEMORY FULL
      FM FILE ACCESS ERROR
      FM SC WORK MEM. ERROR n
      FM ALIGNMENT ERROR
      FM FONT PARSE ERROR
      FM FONT MEMORY FULL
      FM WORK MEMORY ERROR
      IEEE 802.1X error. Set the correct authentication information.
      IEEE 802.1X error. No reply from the destination.
      IEEE 802.1X error. Cannot analyze the certificate.
      IEEE 802.1X error. The certificate is incorrect.
      IEEE 802.1X error. The certificate has expired.
      IEEE 802.1X error. Change the authentication password.
      IEEE 802.1X error. Check the authentication settings.
      Set the IP address.
      Check the server name in the SMB server settings.
      TLS Error
      Cannot delete the default key because it is in use by TLS or other settings. Check the settings.
      TCP/IP Error
      Out of resources. Wait a moment, then try again.
      Check the TCP/IP.
      XPS Print Range Error
      XPS Image Data Error
      XPS Spool Memory Full
      XPS Data Error
      XPS Unsupport Image Err
      XPS Font Error
      XPS Page Data Error
      XPS Memory Full
      You do not have privileges to access the XXX page.
      Access point connection error. Check Wireless LAN Information.
      Cannot start this application because system resources(memory, threads, sockets, file descriptors, disk space,or screen size) required to start the application may notbe available.<Resources>
      Cannot download application logs because application logs do not exist.
      The contents of the file for the application to install are incorrect or information is missing. Check the file.
      The contents of the file for the license to install are incorrect or information is missing. Check the file.
      Could not delete application logs because an error occurred.
      Could not download application logs because an error occurred.
      Could not delete authentication information because an error occurred.
      Could not set authentication information because an error occurred.
      No response.
      Remove the paper from the stack area of the folding unit.
      Cannot recall the settings because the function for the button does not exist.
      Cannot recall the settings because the function for the button is disabled. Enable the function, then try again.
      Check that covers are closed.
      Check the covers.
      The function may be stopped. Buttons could not be imported.
      Place the original on the platen glass.
      Remove the original from the platen glass.
      Original scanning area (feeder) is dirty.
      Original scanning area (thin glass strip) is dirty.
      The number of originals has changed. Return the originals to their correct order, then press the [Start] key.
      Return the originals to their correct order, then press the [Start] key. (The data size of the scanned original exceeds the limit. Settings will be automatically corrected and the originals will be scanned again.)
      The device is currently being used by another user. Wait a while, and then try to perform the operation again.
      The number of search results exceeds the limit. Change search conditions, then try again.
      The search condition includes characters that cannot be used with the selected server.
      An error occurred when verifying.
      This CRL is invalid.
      This CRL has expired.
      This application does not support the security policy function.
      Cannot register because the algorithm of this key is not supported.
      This certificate has been revoked.
      This certificate is invalid.
      This certificate has expired.
      The specified application cannot be installed on this device.
      No response from the server. Check the settings.
      Cannot start searching because the server version settings are incorrect. Check the settings.
      Check the server.
      The appropriate paper size, LTR, is not available.
      There are too many subdirectories.
      Cannot install this application because an applet included in the specified application has exceeded the area that can be displayed in the device panel.
      The following information is missing in file for the specified application. Check the file. <Missing information>
      The specified application does not support this device.
      The contents of the specified file are incorrect or information is missing. Check the file.
      Cannot find the specified application. It may have been uninstalled by another user.
      The contents of the specified file may be incorrect.
      The specified license does not match this device. Specify an installable license.
      The default key is not set. Check the Key and Certificate List settings in Certificate Settings.
      Could not verify the certificate.
      Remove the paper from the booklet tray.
      Cannot connect.
      Cannot change the settings because the selected key is being used.
      Cannot find the selected server. Check the settings.
      Cannot connect to the selected server. Check the settings.
      Could not send.
      Session timed out. Wait a moment, then try to access the database again.
      Cannot complete searching due to timeout. Check the settings.
      Adjusting gradation... Wait a moment.
      Could not access the database. Restart the device.
      Digital Sig. Cert. Access Error
      Certificate Expiration Date Error
      Cannot register any new buttons because the number of registered buttons has reached the limit. Buttons already registered can be overwritten.
      Cannot import because the number of buttons for registration has exceeded the upper limit.
      Could not retrieve the device information details. Do you want to register the device as a destination?
      Replace the toner cartridge.
      Cleaning the drum... Wait a moment.
      Empty the trim waste tray.
      Insert the trim waste tray.
      Remove the paper from the stack area of the trimmer.
      The front cover of the trimmer is open.
      Load staples into the saddle stitch unit.
      The entered PIN is incorrect.
      The authentication server is not running. Contact the system manager.
      Cannot find the authentication server. Contact the system manager.
      A competing IP address was found on the network.
      Could not perform the operation because a network error occurred.
      Check the network connection.
      The hard disk needs to be replaced. (Call service representative.)
      Remove the paper from the output tray.
      Check the staple waste tray.
      Check the punch waste tray.
      Insert the punch cartridge.
      Insert the punch waste tray.
      Empty the punch waste tray.
      Remove the original from the feeder.
      The alignment function of the finisher needs to be checked. Contact your service representative. Printing is still possible.
      The front cover of the finisher is open.
      Performing multiple jobs...
      Cannot log in because an authentication error occurred in Department ID Management. Contact the system manager.
      PDL Invalid DLG Input
      PDL DLG Rendering Error
      PDL DLG Unknown Error
      PDL DLG Memory Full
      PDL DLG Mem. Alloc. Err
      PDL GL Orig. Pt Unknown
      PDL GL Coord.Result
      PDL Invalid GL Input
      PDL GL Range Check
      PDL GL Memory Full
      PDL GL Mem. Alloc. Err
      PDL PCL Initial. Error
      PDL PCL Process Error
      PDL PCL Work Memory Full
      PDL PCL DL Memory Full
      PDL IMG Refer. Data Err
      PDL IMG Initial. Err
      PDL IMG Process. Error
      PDL IMG Invalid Data
      PDL IMG Work Memory Full
      PDL nn Rendering Error (Where "nn" is a module name)
      PDL PDF Error
      PDL PDF Data Decode Err
      PDL PDF Memory Full
      PDL RIP Process. Error
      PDL XPS Rendering Error
      PDL Image Comp. Error
      PDL Rendering Timeout
      PDL Data Transfer Error
      PDL Reg. Access Error
      Cannot recall the button settings because other operations are being performed.
      Register to Quick Menu will be canceled and you will be returned to the function screen because you do not have permission to register buttons. Log in as an administrator, then try again.
      Load staples into the stapler unit.
      Wireless LAN communication error. Turn main power OFF and ON.
      Wireless LAN comm. error. Check Wireless LAN Information.
      Cannot send because the memory is full. Wait a moment, then try again.
      Could not perform the operation because the memory is full.
      Scanning will be canceled because the memory is full. Do you want to print the scanned pages?
      Scanning will be canceled because the memory is full. Wait a moment, then try again.
      Scanning will be canceled because the memory is full. Do you want to send the scanned pages?
      Scanning will be canceled because the memory is full. Do you want to store the scanned pages?
      Register to Quick Menu will be canceled because you are not logged in. Return to the function screen, log in, then try again.
      Check the user name, password, or settings.
      Load paper.
      Scanning was canceled because the data size of the scanned original exceeds the limit. Scanning may be possible if sharpness is reduced, or Original Type is set to Text.
      Login failed. Anonymous access to the authentication server is not allowed. Contact the system manager.
      Login failed. The account information necessary to log in to the authentication server is invalid. Contact the system manager.
      Cannot store the password because the number of passwords stored for each user has reached the limit.
