      0WR6-0WL
      <Common Settings>
      You can register/change the common settings for sending documents.
      Item
      Description
      <Register Favorite Settings>
      You can register frequently used settings in a button of the machine for later use when scanning. You can also assign your favorite name to a button and enter a comment such as information about the button settings.
      Setting Value
      Buttons where settings are to be registered: <M1> to <M18>
      <Show Comments>: <On>, <Off>
      <Name>: <M1> to <M18>
      <Comment>: Enter a comment.
      NOTE:
      If a destination included in a button is deleted from the Address Book, it is also deleted from the settings registered in the button.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
      Device Information Distribution Available: Yes
      <Edit Favorite Settings>
      You can delete the settings registered as “Favorite Settings” and change the name of a button.
      Setting Value
      <Delete>, <Check Content> (→), <Rename> (→), <Show Comments>:<On>, <Off>
      <Check Content>: Check the registered settings.
      <Rename>: Change a button name or comment.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Device Information Distribution Available: No
      <Display Confirmation for Favorite Settings>
      You can select whether to display a confirmation screen when recalling “Favorite Settings.”
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Default Screen>
      You can specify a screen that you want to display when you press <Scan and Send> on the Main Menu, when Auto Reset is activated, or when you press .
      Setting Value
      <Standard>, <One-Touch>, <Favorite Settings>, <Address Book>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Change Default Settings>
      You can change and register some scan settings of <Scan and Send> on the Main Menu as default settings.
      Setting Value
      <Register>, <Initialize>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Register Options Shortcuts>
      You can register shortcuts to the function setting buttons you frequently use. The registered shortcuts are displayed on the Scan Basic Features screen.
      Setting Value
      Shortcut button 1: <2-Sided Original>
      Shortcut button 2: <Different Size Originals>
      Function setting buttons you can register:
      <Original Type>, <2-Sided Original>, <Book  2 Pages>, <Different Size Originals>, <Density>, <Sharpness>, <Copy Ratio>, <Erase Frame>, <Job Build>, <Delayed Send>, <Preview>, <Finished Stamp>, <Job Done Notice>, <File Name>, <Subject/Message>, <Reply-to>, <E-Mail Priority>, <TX Report>, <Orig. Content Orientation>, <Skip Blank Originals>, <Detect Feeder Multi Sheet Fd.>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <TX Report>
      A TX Report is a report that enables you to check whether documents were sent correctly to their intended destinations. The machine can be set to print this report automatically after documents are sent or only when a transmission error occurs. You can also specify the setting to print the first part of the document as part of the report to remind you of the document's contents. TX Report
      Setting Value
      <For Error Only>, <On>, <Off>
      When <For Error Only> or <Off> is selected
      <Allow Printing from Options>: <On>, <Off>
      <Report with TX Image>: <On>, <Off>
      When <On> is selected
      NOTE:
      Reports and lists can be printed on 11" x 17", LGL, or LTR paper. However, they may not be printable depending on the paper type.
      DeviceAdmin: Yes
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      <Communication Management Report>
      You can print a list of results for sending/receiving documents as a report. The machine can be set to print this report automatically when the number of communication results reaches 100 or at a specified time. The send and receive results can also be printed separately. Communication Management Report
      Setting Value
      <Auto Print (100 Transmissions)>: <On>, <Off>
      <Specify Print Time>: <On>, <Off>
      <Separate TX/RX>: Enabled, Disabled
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <TX Terminal ID>
      You can select whether to add the sender information to the top of a sent document when sending a fax/I-fax. Information such as the fax number, name, and I-fax address of the machine is printed, enabling the recipient to check who sent the document.
      Setting Value
      <Print>, <Do Not Print>
      When <Print> is selected
      <Print Position>: <Inside>, <Outside>
      <Display Destination Unit Name>: <On>, <Off>
      <Telephone No. Mark>: <Fax>, <TEL>
      NOTE:
      When sending a remote fax, the sender information depends on the setting of the Remote Fax server.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Delete Failed TX Jobs>
      You can select whether to automatically delete a document from memory when the sending/saving error occurs. Selecting <Off> enables you to resend/resave the documents that failed to send/save.
      Checking Status and Log for Sent and Received Documents
      Checking Status and Log for Scanned Documents
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Retry Times>
      You can set the machine to automatically try to resend data when the data cannot be sent. This may occur because the recipient is busy sending or receiving, or when an error occurs. This setting determines the number of retry attempts.
      Setting Value
      0 to 3 to 5 times
      NOTE:
      This setting is disabled when sending faxes.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Data Compression Ratio>
      You can set the compression ratio for color/grayscale scanned data.
      Setting Value
      <High Ratio>, <Normal>, <Low Ratio>
      NOTE:
      If you want to select compact or trace & smooth for the PDF file format or select compact for the XPS file format, it is recommended that you set <Data Compression Ratio> to <Normal> or <Low Ratio>. If you set to <High Ratio>, images may be output in low quality even if you select <Generate File> <Image Quality Level for Compact> <Quality Priority>.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <YCbCr TX Gamma Value>
      If you are sending a document in color or grayscale, you can specify the gamma value to use when converting scanned RGB image data to YCbCr. You can reproduce the image with the optimal image quality at the recipient by setting an appropriate gamma value when sending image data.
      IMPORTANT:
      This setting is disabled for the following file formats:
      PDF (Compact)
      XPS (Compact)
      PDF (Trace & Smooth)
      Setting Value
      <Gamma 1.0>, <Gamma 1.4>, <Gamma 1.8>, <Gamma 2.2>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Use Divided Chunk Send for WebDAV TX>
      You can divide data into chunks when sending with WebDAV. Chunked encoding is a function for sending a file with an unknown size by dividing it into chunks of a known length. It enables the sending time to be reduced because it is not necessary to calculate the size of the file before sending it.
      IMPORTANT:
      You may not be able to send files with chunked encoding, depending on certain conditions for the WebDAV server and proxy server.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Confirm TLS Certificate for WebDAV TX>
      You can check whether the TLS server certificate is valid when sending with WebDAV. You can verify the validity of the certificate and reliability of the certificate chain, as well as confirm the CN (Common Name).
      IMPORTANT:
      If you do not verify the certificate, TLS communication is performed, even with an invalid certificate.
      Setting Value
      <On>, <Off>
      <CN> for <Add Items to Verify>: Enabled, Disabled
      NOTE:
      If there is a problem with the certificate, WebDAV sending will fail.
      DeviceAdmin: No
      NetworkAdmin: No
      The destinations that can be specified when sending faxes or scanned documents can be restricted to those registered in the Address Book or one-touch buttons, those registered in <Favorite Settings> or <Send to Myself>, or those that can be searched on the LDAP server. When this function is enabled, users cannot specify destinations using alphanumeric character input. Restricting New Destinations
      <Always Add Device Signature to Send>
      You can select whether to always add a device signature to sent PDF/XPS files.
      Setting Value
      <On>, <Off>
      <Restrict File Formats>: <On>, <Off>
      NOTE:
      If you set <Restrict File Formats> to <On>, files other than PDF/XPS cannot be sent.
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Limit E-Mail to Send to Myself>
      The destination that can be specified when sending an e-mail can be restricted to the e-mail address of a user who logs in to the machine with personal authentication management. This setting enables you to prevent information leakage due to a transmission to a wrong destination.
      IMPORTANT:
      This setting applies to a user with the role of <GeneralUser>.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Restrict File TX to Personal Folder>
      The destination that can be specified when saving in a file server can be restricted to the personal folder of a user who logs in to the machine with personal authentication management. This setting enables you to prevent information leakage due to a transmission to a wrong destination.
      IMPORTANT:
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Personal Folder Specification Method>
      Users who log in with personal authentication management can create a Personal folder for individual use. A Personal folder can be specified as the send destination for scanned documents, and it can be created in a shared folder or on a file server. Users can easily send documents to their Personal folders, which can effectively prevent information leakage due to operation errors. Configuring Personal Folders
      Setting Value
      <Home Folder>, <Register for Each User>, <Use Login Server>
      When <Home Folder> is selected
      <Home Folder Settings>: No Settings, <Use Authentication Info. of Each User>: Enabled, Disabled
      When <Use Login Server> is selected
      DeviceAdmin: Yes
      NetworkAdmin: No
      <Restrict Resending from Log>
      You can select whether to prevent users from recalling the logs for the destinations and scan settings specified in the past. Selecting <On> hides the <Previous Settings> buttons from both the Fax Basic Features screen and the Scan Basic Features screen.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      <Settings for Sent Document Backup>
      You can save a copy of a sent fax in a specified file server. The copy is converted into an electronic file such as PDF and saved at the same time as sending, allowing you to organize it neatly and compactly. This method also helps you easily manage the logs of documents because a folder categorized by sender name or date and time is automatically created in the server.
      Setting Value
      <Use Sent Document Backup Function>: <On>, <Off>
      <Backup Location>: Select a destination from the Address Book.
      <Folder Name> (→)
      <File Format>: <TIFF>, <PDF>
      <Folder Name>
      <Create Folder for File Backup Based On>: <Sender Information>, <Date>, <Off (Do Not Create)>
      DeviceAdmin: No
      NetworkAdmin: No
      <Display Notification When Job Is Accepted>
      You can select whether to display a screen prompting you to check the communication status after sending/saving documents from <Fax> or <Scan and Send> on the Main Menu.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
