Item
Description
Specify settings for using the machine in a IPv4 network.
Specify settings for using the machine in a IPv6 network.
Specify DNS settings for using the machine.
<Computer Name/Workgroup Name Settings>
Specify the NetBIOS name and workgroup name.
Setting Value
<Computer Name>: Enter the computer name.
<Workgroup Name>: Enter the workgroup name. <Comment>: Enter the comment. DeviceAdmin: Yes
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<SMB Server Settings>
Specify the SMB server settings to open the Advanced Box to the public in a network.
Setting Value
<Use SMB Server>: <On>, <Off>
<Require SMB Signature for Connection><On>, <Off> <Use SMB Authentication><On>, <Off> <Authentication Type>: <NTLMv1>, <NTLMv2> DeviceAdmin: Yes
<WINS Settings>
Specify settings for Windows Internet Name Service (WINS), which provides a NetBIOS name for IP address resolutions in a mixed network environment of NetBIOS and TCP/IP.
Setting Value
<WINS Resolution>: <On>, <Off>
<WINS Server Address>: 0.0.0.0 DeviceAdmin: No
<LPD Print Settings>
Enable or disable LPD, a printing protocol that can be used on any hardware platform or operating system.
Setting Value
<On>, <Off>
<LPD Banner Page>: <On>, <Off> <RX Timeout>: 1 to 5 to 60 (min.) DeviceAdmin: No
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: Yes |
<RAW Print Settings>
Enable or disable RAW, a Windows specific printing protocol.
Setting Value
<On>, <Off>
<Bidirectional Communication>: <On>, <Off> <RX Timeout>: 1 to 5 to 60 (min.) DeviceAdmin: No
<SNTP Settings>
Specify settings for Simple Network Time Protocol (SNTP). Making SNTP Settings
Setting Value
<Use SNTP>: <On>, <Off>
<Polling Interval>: 1 to 24 to 48 (hr.) <NTP Server Address>: Enter the NTP server address. <Check NTP Server> DeviceAdmin: No
<FTP Print Settings>
Enable or disable FTP Print.
Setting Value
<Use FTP Printing>: <On>, <Off>
<User Name>: Enter the user name. (guest) <Password>: Enter the password. (7654321) DeviceAdmin: No
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: <Use FTP Printing> only |
<Use UTF-8 to Display Name of FTP Print Job>
Specify whether to use UTF-8 for displaying file names when you perform FTP print.
Setting Value
<On>, <Off>
DeviceAdmin: No
<WSD Settings>
Specify the WSD settings.
Setting Value
<Use WSD>: <On>, <Off>
<Use WSD Browsing>: <On>, <Off> <Use WSD Scan Function>: <On>, <Off> DeviceAdmin: No
<Use FTP PASV Mode>
Enable or disable FTP PASV mode setting. Setting the PASV Mode of FTP
Setting Value
<On>, <Off>
DeviceAdmin: No
<IPP Print Settings>
Specify the IPP print settings.
Setting Value
<On>, <Off>
<Use TLS>: <On>, <Off> <Use Authentication>: <On>, <Off> DeviceAdmin: No
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: <On> / <Off> for <IPP Print Settings> only |
<Multicast Discovery Settings>
Specify the multicast discovery settings. Monitoring the Machine From Device Management Systems
Setting Value
<Response>: <On>, <Off>
<Scope Name>: Enter the scope name. DeviceAdmin: No
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: <Scope Name> cannot be distributed |
<Use HTTP>
Enable or disable HTTP setting.
Setting Value
<On>, <Off>
NOTE:
If you select <Off>, <IPP Print Settings> and <Remote UI> is accordingly set to <Off>.
DeviceAdmin: No
<Use WebDAV Server>
Specify whether to use the WebDAV server. Making WebDAV Settings
Setting Value
<On>, <Off>
DeviceAdmin: No
<TLS Settings>
You can set the currently used keys after checking the functions that use TLS encrypted communication.Configuring the Key and Certificate for TLS
Setting Value
<Key and Certificate> (→
) <Key and Certificate>: <Set as Default Key>, <Certificate Details>, <Display Use Location>DeviceAdmin: No
<Proxy Settings>
Specify settings for the proxy.Setting a Proxy
Setting Value
<Use Proxy>: <On>, <Off>
<Server Address>: Enter the proxy server address. <Port Number>: 1 to 80 to 65535 <Use Proxy within Same Domain>: <On>, <Off> <Set Authentication> (→ ) <Set Authentication><Use Proxy Authentication>: <On>, <Off>
<User Name>: Enter the user name. <Password>: Enter the password. DeviceAdmin: No
<Confirm Auth. Info. When in Auth. Management Mode>
Specify whether the machine checks the authentication information when you print using the drivers that support Windows Vista/7.
Setting Value
<On>, <Off>
DeviceAdmin: No
<IPSec Settings>
Specify the IPSec settings. Configuring the IPSec Settings
Setting Value
<Use IPSec>: <On>, <Off>
<Use IPSec> sets to <On>.
<Receive Non-Policy Packets>: <Allow>, <Reject> <Policy On/Off>: Enable or disable selected policy. <Register> (→ )<Edit> (→ )<Delete>: Delete the policy. <Raise Priority>, <Lower Priority>: Select the priority of each policy. <Print List>: Print setting list. <Register>, <Edit><Policy Name>: Enter the policy name.
<Selector Settings> (→ )<IKE Settings> (→ )<IPSec Network Settings> (→ ) <Selector Settings><Local Address>: <All IP Addresses>, <IPv4 Address>, <IPv6 Address>, <IPv4 Manual Settings> (→
), <IPv6 Manual Settings> (→ )<Remote Address>: <All IP Addresses>, <IPv4 Address>, <IPv6 Address>, <IPv4 Manual Settings> (→ ), <IPv6 Manual Settings> (→ )<Port>: <Specify by Port Number> (→ ), <Specify by Service Name> (→ ) <IKE Settings><IKE Mode>: <Main>, <Aggressive>
<Authentication Method> <Pre-Shared Key Method>: Specify the shared key from <Shared Key>. <Digital Sig. Method> selected : <Key and Certificate> (→ )<Authentication/Encryption Algorithm>: <Auto>, <Manual Settings> (→
) <IPSec Network Settings><Validity>: Specify the time or size of the valid data.
<PFS>: <On>, <Off> <Authentication/Encryption Algorithm>: <Auto>, <Manual Settings> (→ )<Connection Mode>: <Transport>
<Local Address: IPv4 Manual Settings><Single Address>: Enter the IP address.
<Address Range>: Enter <First Address> and <Last Address>. <Subnet Settings>: Enter <Address> and <Subnet Mask>. <Local Address: IPv6 Manual Settings><Single Address>: Press <Address>, and Enter the IP Address.
<Address Range>: Enter <First Address> and <Last Address>. <Specify Prefix>: Enter <First Address> and specify <Prefix Length>. <Specify by Port Number><Local Port>: Select <All Ports> or <Single Address>. When you select <Single Address>, enter the port number.
<Remote Port>: Select <All Ports> or <Single Address>. When you select <Single Address>, enter the port number. <Specify by Service Name>Enable or disable <Service On/Off>.
<Key and Certificate>: Select the displayed key.<Set as Default Key>, <Certificate Details>, <Display Use Location>
<Authentication/Encryption Algorithm: Manual Settings><Authentication>: <SHA1>, <SHA2>
<Encryption>: <3DES-CBC>, <AES-CBC> <DH Group>: <Group 1 (768)>, <Group 2 (1024)>, <Group 14 (2048)>, <ECDH-P256>, <ECDH-P384> <Authentication/Encryption Algorithm: Manual Settings>: <ESP>, <ESP (AES-GCM)>, <AH (SHA1)>Selecting <ESP>,
<ESP Authentication>: <SHA1>, <NULL> <ESP Encryption>: <3DES-CBC>, <AES-CBC>, <NULL> DeviceAdmin: No
<SIP Settings>
Specify SIP settings. For information about SIP settings, see IP FAX Expansion Kit User's Guide
<Use Network Link Scan>
Specify whether to use Network Link Scan.
Setting Value
<On>, <Off>
DeviceAdmin: No
