Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Auto Adjust Gradation]
Full Adjust: (Automatic after the machine prints and scans three sets of test pages): Press [Start Printing]
Quick Adjust: Press [Start]
No
No
[Correct Density]
Black Scan for Copy/Scan and Store (Mail Box), Black Scan for Send/Scan and Store (Other Than Mail Box), Color Scan for Send/Scan and Store: 9 levels each
5 levels
No
No
[Correct Shading]
Densitometer Correction, Visual Correction
No
No
[Auto Correct Color Mismatch]
Start key
No
No
[Full Color Printing Vividness Settings]
Standard, Level 1, Level 2
Standard
No
No
[Fine Adjust Zoom]
X: -1.0% to +1.0%, in 0.1% increments
Y: -1.0% to +1.0%, in 0.1% increments
X: 0%
Y: 0%
No
No
[Dither Pattern Settings]
Pattern 1, Pattern 2
Pattern 1
No
No
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Saddle Stitcher Staple Repositioning]*1
Start key
No
No
[Change Fold/Stitch Position]*1
-2.00 mm to +2.00 mm, in 0.25 mm increments
0.00 mm
No
No
[Adjust Saddle Stitch Fold Position]*1
0.00 mm
No
No
[Adjust Double Staple Width]*1
4 3/4", 5 11/16"
5 11/16"
No
No
[Finisher Puncher Switch]*1
Speed Priority, Precision Priority
No
No
[Adjust Trim Width]*1
-2.0 mm to +20.0 mm, in 0.1 mm increments
2.0 mm
No
No
[Color/Black Priority for First Print Time]
Color Priority, Black Priority
Black Priority
No
No
[Adjust Fold Position]*1
[Adjust Z-Fold Position]
-2.0 mm to +1.5 mm, 0.5 increments
0.0 mm
No
No
[Adjust C-Fold Position]
When the Paper Folding Unit-G1 is attached:
-7.0 mm to +5.0 mm, in 0.5 mm increments
-1.0 mm
No
No
When the Document Insertion/Folding Unit-G1 is attached:
A: 0.0 mm to +6.0 mm, 0.5 mm increments
B: 0.0 mm to 3.0 mm, 0.5 mm increments
0.0 mm
No
No
[Adjust Accordion Z-Fold Position]
-7.0 mm to +5.0 mm, 0.5 increments
-1.0 mm
No
No
[Adjust Double Parallel Fold Position]
A: -2.0 mm to +5.0 mm, 0.5 increments
B: 0.0 mm to +5.0 mm, 0.5 mm increments |
A: -1.0 mm
B: 1.0 mm |
No
No
[Adjust Half Fold Position]
-2.0 mm to +2.0 mm, 0.5 increments
0.0 mm
No
No
[Adjust Saddle Fold Position]
-2.00 mm to +2.00 mm, 0.25 increments
0.00 mm
No
No
[Adjust Paper Deck Plates]*1
Start key
No
No
[Correct Curl for Each Paper Drawer]*1
Face Up Output (Reverse): -10 to +10
Face Down Output (Normal): -10 to +10 |
0
No
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Clean Feeder]*1
Start key
No
No
[Clean Wire]
Start key
No
No
[Clean Roller]
Start key
No
No
[Clean Drum]
Start key
No
No
[Original Scanning Area Cleaning Method]*1
Displaying cleaning method
No
No
*1
