CAUTION |
Note that this feature may affect paper feeding. Since increasing the value to a great extent may cause paper jams, adjusting the values in small increments is recommended.
If you adjust the level of curl correction in [Paper Type Management Settings] in [Preferences], make sure to reset the value in this mode to '0'. (See "Registering/Editing Custom Paper Types.")
Depending on the environment where the paper is stored, the condition of the paper, such as moisture in the paper, may differ. If the condition of the paper is different than usual, you can adjust the curl correction level of each paper source individually for a better result.
This function can be adjusted if the finisher is attached.
(Settings/Registration).|
To determine the direction of the paper curl, place the paper in the direction where the paper is output to the output tray.
Adjust the curl correction level in the direction opposite to that of printed paper.
