Saddle Stitch Staple Repositioning
You can reposition the stapler of the saddle stitcher unit after clearing a staple jam, or after replacing the staple cartridge. Saddle stitch staple repositioning works by feeding several sheets of paper into the saddle stitcher unit and stapling them together.
This mode can be set when the Booklet Finisher-L1 is attached. (See "Staple Finisher-L1/Booklet Finisher-L1/External 2/3 Hole Puncher-A1.")
Only use 12" x 18", 11" x 17", LGL, or LTRR paper for the saddle stitch staple repositioning procedure.
Make sure to remove all output booklets from the Booklet Tray before performing the saddle stitch staple repositioning procedure.
Press [Adjustment/Maintenance] → [Adjust Action] → [Saddle Stitcher Staple Repositioning].
Press [Start].
Paper that is required for the saddle stitch staple repositioning procedure is automatically fed to the saddle stitcher unit by the machine.
» Settings/Registration » Adjustment/Maintenance » Adjust Action » Saddle Stitch Staple Repositioning
08JK-080
