This mode is enabled if you select [Full Color] in [Select Color] for the Copy or Access Stored Files function, or if the machine detects that the original is in full color when [Auto (Color/Black)] is selected.
(Settings/Registration).|
This setting is enabled only after you restart the machine (the main power switch is turned OFF, and then back ON). For information on how to turn ON and OFF the main power of the machine, see "Before You Start Using This Machine."
