Adjusting the Paper Folding Position
You can adjust the folding positions of the paper when a folding mode is set.
The C-fold or Z-fold positions can be adjusted when the Paper Folding Unit-G1 or the Document Insertion/Folding Unit-G1 is attached. (See "
Paper Folding Unit-G1" or "
Document Insertion/Folding Unit-G1/Document Insertion Unit-J1.")
The half fold, accordion Z-fold, or double parallel fold positions can be adjusted when the Paper Folding Unit-G1 is attached.
(See "Paper Folding Unit-G1.")
Press
(Settings/Registration).
Press [Adjustment/Maintenance] → [Adjust Action] → [Adjust Fold Position].
Select the method for the folding position of paper.
To adjust the position of the Saddle Folding, select the paper size you want to change.
4.
Adjust the folding position by pressing [
] or [
] → press [OK].
If you selected [Adjust Double Parallel Fold Position], adjust the two folding positions (A and B).
If you selected [Adjust C-Fold Position] when the Document Insertion/Folding Unit-G1 is attached, adjust the two folding positions (A and B).
