Category Top
System Requirements
Before Using the Network Scanner
Installation
Selecting the Scanner
Scanning Fundamentals
Switching the Scanner Online and Offline
Scanning from the Platen Glass
Scanning from the Feeder
Viewing the Online Help
Scanning Originals with Correct Orientation
Scanning Different Sized Originals Together
Specifying the Scanning Area
Department ID Management
Setting a Department ID and PIN Beforehand
Entering the Department ID and PIN When You Scan
Questions & Answers
Select [Background Density] for [Image Quality Adjstmnt] in the [Main] sheet.
Click [Fine Adjustment] → adjust each color by moving the sliders in the [Adjustments for Background Density] dialog box.
Right-click in the Preview Area to display a pop-up menu.
On the pop-up menu, point to [Original Frame Erase] → click [On].
Click [
](Start) → [Control Panel] → [System and Security] → [Windows Firewall] → [Advanced Settings]. |
Select [Inbound Rules] in the [Windows Firewall with Advanced Security] sheet → click [New Rule].
In [New Inbound Rule Wizard], select [Port] → click [Next].
4.
Select [UDP] → enter 56338 in [Specific local port] → click [Next].
5.
Select [Allow the connection] → click [Next].
6.
Select only [Private] → click [Next].
7.
Enter a name in [Name] → click [Finish] to close [New Inbound Rule Wizard].
Click [
](Start) → [Control Panel] → [Security] → [Windows Firewall] → [Allow a program through Windows Firewall]. |
In the [Exceptions] sheet, click [Add Port].
In the [Add a Port] dialog box, enter a name for [Name] → enter 56338 for [Port number] → select the check mark next to [UDP] → click [OK].
4.
Click [OK] and close the [Windows Firewall] dialog box.
Click [Start] → [Control Panel] → [Security Center] → [Windows Firewall] under [Manage security setting for].
4.
The above procedures vary according to the edition and system settings of the operating system you are using.
