NetWare Network Setup Procedures
To use a NetWare network, it is necessary to perform the following procedures.
Specify the NetWare print service settings. To specify the settings from the computer, use one of the following:
NWADMIN or PCONSOLE (Novell software provided with NetWare)
Canon utilities
Specify the protocol settings. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
Canon utilities
Specify the settings of each computer you use for printing.
It is recommended that you consult the administrator for the network you are using when performing the settings in steps 1 and 2.
To configure settings with software other than the control panel of the machine, NWADMIN, or PCONSOLE, TCP/IPv4 protocol must be supported by your network environment (IPv6 is not supported).
