e-ManualTopSite mapHelp
Top » Network » TCP/IP Network Setup Procedures
0UKW-0UE
To use a TCP/IP network, it is necessary to perform the following procedures.
1.Protocol Settings
Specify the protocol settings. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
Canon utilities
2.Setting Up a Computer for Printing
Specify the settings of each computer you use for printing.
It is recommended that you consult the administrator for the network you are using when performing the settings in step 1.
The machine or printing equipment does not come with printer driver software that can be used on a UNIX platform. (Use LPD to set up a printer in UNIX.)
Pre-determined ports must be opened in order to initiate network communication using TCP/IP. The required ports can be opened by selecting [On] for the appropriate [Network] settings in the machine. It is recommended that the settings for any unused functions be set to 'Off'. When a port is opened, it is possible for a third person to gain unauthorized access.
