Overview of This Function
0UKW-0AJ
The Quick Menu is a function that increases the efficiency of operations that use functions of the machine for an office. You can create and register frequently used function settings such as Access Stored Files in a button.
There are two types of buttons: the Shared Button that can be used by all users and the Personal Button that can only be set and used by each user.
You can access the machine via a Web browser to import and export the Personal buttons/Shared buttons.
With the Quick Menu function, you can register the following function settings in a button:
The flow of registering settings in Personal buttons/Shared buttons is indicated below.
