e-Manual
Top
Site map
Help
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Access Stored Files
Secure Print
Web Access
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
How to Use This Manual
Expand all
Collapse all
Category Top
Overview of This Function
Using the Quick Menu from the Machine
Quick Menu Screen Operations
Registering a Personal Button/Shared Button
Recalling a Personal Button/Shared Button
Editing a Personal Button/Shared Button
Changing the Size of Buttons
Specifying the Wallpaper Settings
Restricting Access to the Quick Menu
Importing/Exporting the Personal Buttons/Shared Buttons
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Access Stored Files
Secure Print
Web Access
Quick Menu
Print
Network
Remote UI
MEAP
Security
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Quick Menu
0UKW-0AX
Press [Quick Menu].
Press
Press [Wallpaper Settings].
4.
Select the button to set the wallpaper for → select the wallpaper settings → press [OK].
Back to Top
