Top » Maintenance » Loading Paper » Loading Transparencies
0R9W-0HH
Transparencies have a front and back side. To obtain clear images, load the side to print on correctly according to the paper source.
You can load only LTR size transparencies.
When loading transparencies, make sure to hold only the edges of the sheets and avoid touching the print surface.
Do not load transparencies while the machine is printing. Doing so may cause a paper jam.
Use only transparencies intended for use with this machine. If you use other transparencies, you may cause damage to the machine.
It is recommended that output transparencies are immediately removed from the output tray to avoid folding of the transparencies and paper jams.
Return the remaining transparencies to their original package for storage, avoiding locations subject to high temperatures and humidity. Leaving transparencies loaded for an extended period of time may cause the sheets to stick together and result in a paper jam.
Fan the transparencies well before loading them. Leaving transparencies loaded for an extended period of time may cause the sheets to stick together and result in difficulties feeding the transparencies.
When printing on transparencies, depending on the type of image, the image may become dense. When this happens, adjust the density for the output image.
If a paper jam occurs, fan the loaded transparency sheets well.
