e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
Authentication
Security
Practical Workflows
How to Use This Manual
Expand all
Collapse all
Category Top
Loading Paper
Loading Paper into a Paper Drawer
Loading Envelopes
Loading Pre-Punched Paper
Loading Transparencies
Replacement Parts
Replacing the Stamp Cartridge (Feeder)
Replacing the Staple Cartridge (For Optional Products)
Replacing the Staple Case in the Stapler Unit (Staple Finisher-U1/Booklet Finisher-U1)
Replacing the Staple Cartridge in the Saddle Stitcher Unit (Booklet Finisher-U1)
Replacing the Staple Case (Inner Finisher-G1)
Replacing the Toner Cartridge
Replacing the Waste Toner Container
Replacing the Drum Unit
Routine Cleaning
Originals Cannot Scanned Properly (Cleaning the Platen Glass)
Originals Loaded in the Feeder and Prints Become Dirty (Manual Feeder Cleaning)
Scanned Originals Become Dirty (Automatic Feeder Cleaning)
Output Paper Becomes Dirty (Cleaning Inside of the Main Unit)
When White Streaks Appear on Prints (Cleaning the Dust Proof Glass)
Consumables
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
Authentication
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Maintenance
Replacement Parts
0R9W-0HL
This section describes how to replace the staple case and staple cartridge in the stapler unit and saddle stitcher unit.
Back to Top
