Top » Maintenance » Routine Cleaning
Routine Cleaning
0R9W-0J0
If an original is not copied clearly, clean the platen glass, the underside of the feeder, the document feed scanning area, and the rollers of the feeder. For high-quality printouts, we recommend cleaning these parts once or twice a month.
The proper cleaning method for various cases is shown by the marks below.
Case 1
Adhesive and other easy to remove substances
Clean the machine with the glass cleaning sheet included with the machine.
Case 2
Ink and other difficult to remove substances
Clean the machine with a cloth which is wrung after being dampened in water, and then wipe it clean with a soft, dry cloth.
Case 3
Stains that cannot be removed with a wet cloth
Clean the machine with a cloth dampened with a mild detergent mixed with water, and then wipe it clean with a soft, dry cloth.
WARNING
When cleaning the machine, first turn Off the main power switch, and disconnect the power cord. Failure to observe these steps may result in a fire or electrical shock.
Disconnect the power cord from the power outlet regularly, and clean the area around the base of the power plug's metal pins and the power outlet with a dry cloth to ensure that all dust and grime is removed. If the power cord is connected for a long period of time in a damp, dusty, or smoky location, dust can build up around the power plug and become damp. This may cause a short circuit and result in a fire.
When cleaning with a cloth, do not dampen the cloth too much, as this may damage the original or break the machine.
Do not use alcohol, benzene, paint thinner, or other solvents for cleaning. Doing so may result in damage to the plastic parts.
