Top » Maintenance » Consumables
Consumables
0R9W-0J6
The following consumables are available from Canon. For more information, contact your local authorized Canon dealer.
We recommend that you order paper stock and toner from your local authorized Canon dealer before your stock runs out.
Recommended Paper
In addition to plain paper (12" x 18", 11" x 17", LGL, LTR, STMT, and EXEC sizes), recycled paper, color paper, transparencies (recommended for this machine), tracing paper, labels, and other types of paper stock are available.
CAUTION
Do not store paper in places exposed to open flames, as this may cause the paper to ignite, resulting in burns or a fire.
Some commercially available paper types are not suited for this machine. Contact your local authorized Canon dealer when you need to purchase paper.
To prevent moisture build-up, tightly wrap any remaining paper in its original package for storage.
For high-quality printouts, use paper recommended by Canon.
Toner
Confirm that the code on the front cover of the machine and the one on the package of the genuine toner are the same.
If a message prompting you to replace the toner cartridge appears on the touch panel display, replace the used toner cartridge of the displayed color with a new one.
Toner comes in four colors: black, cyan, magenta, and yellow.
Check the toner color that you need to replace before ordering toner from your local authorized Canon dealer. Also, when replacing the toner cartridge, make sure that you replace toner of the correct color.
Use only toner cartridges intended for use with this machine.
For optimum print quality, using Canon genuine toner is recommended.
For information on the dedicated toner cartridge item numbers for this machine, see "Replacement Parts."
WARNING
Do not burn or throw used toner cartridges into open flames, as this may cause the toner remaining inside the cartridges to ignite, resulting in burns or a fire.
Do not store toner cartridges in places exposed to open flames, as this may cause the toner to ignite, resulting in burns or a fire.
If you accidentally spill or scatter toner, carefully wipe up the loose toner with a damp, soft cloth and avoid inhaling any toner dust. Do not use a vacuum cleaner that is not equipped with safety measures to prevent dust explosions to clean up loose toner. Doing so may cause damage to the vacuum cleaner or result in a dust explosion due to static discharge.
CAUTION
Keep toner out of the reach of small children.
If toner is ingested, consult a physician immediately.
Store toner cartridges in a cool location, away from direct sunlight. (The recommended storage conditions are temperatures below 86°F and humidity below 80%.)
Do not store toner cartridges in an upright position.
[Be careful of counterfeit toners]
Please be aware that there are counterfeit Canon toners in the marketplace. Use of counterfeit toner may result in poor print quality or machine performance. Canon is not responsible for any malfunction, accident or damage caused by the use of counterfeit toner.
For more information, see canon.com/counterfeit.
Drum Unit
When you replace the drum unit with a new one, be sure to use only drum units intended for use with the machine. For optimum print quality, using Canon genuine drum unit is recommended.
For information on the drum unit item numbers for this machine, see "Replacement Parts."
CAUTION
For cardiac pacemaker users:
This drum unit emits low level magnetic flux. If you use a cardiac pacemaker and feel abnormalities, please move away from the drum unit, and consult a physician.
Stamp Ink Cartridge
The stamp ink cartridge is used to stamp originals. Use the tweezers provided to remove and replace the stamp ink cartridge.
Stamp Ink Cartridge-C1
Staple Cartridge
Finisher
Name
Shape
Staple Finisher-U1
Staple-J1
Booklet Finisher-U1
Staple Cartridge-D2
Staple Cartridge-D3
Staple-J1
Inner Finisher-G1
Staple-P1
Genuine Supplies
Canon has developed and manufactured Toner, Parts, and Supplies specifically for use in this machine.
For optimal print quality and for optimal machine performance and productivity, we recommend that you use Genuine Canon Toner, Parts, and Supplies.
Contact your Canon Authorized Dealer or Service Provider for Genuine Canon Supplies.
