Top » Fax/I-Fax Inbox » Memory RX Inbox » Memory RX Inbox » Checking the Detailed Information for/Displaying an Image/Deleting a File in the Memory RX Inbox
0R9W-16F
Checking the Detailed Information for a File
Press [Fax/I-Fax Inbox] → [Memory RX Inbox].
Press [Memory RX Inbox].
Select a file to check → press [Details].
If you select multiple files and press [Details], only the details of the selected (highlighted) file appear.
Displaying the Image of a File
Select the file that you want to display → press [Display Image].
4.
Press  or  → select the page to check → check the image.
You can press  (reduce) or  (enlarge) to zoom in or out.
You can press , , , or  to specify the area to display when you zoom in or out on the page.
If you select multiple files, only the contents of the selected (highlighted) files are displayed.
Deleting a File
Select the file that you want to delete → press [Delete].
You can cancel a selection by selecting the file again.
To deselect all files, press [Clear Selection]. ([Clear Selection] changes to [Select All (Max 32 Files)].)
4.
Press [Yes].
You cannot delete multiple files simultaneously. To delete multiple files, select and delete one file at a time.
