Finishing with the Stapler
You can bind each copy with the stapler after a collate or group output.
1
Place the original.
Placing Documents
2
Press <Copy> on the Main Menu.
<Main Menu> Screen
3
Press <Options> on the Copy Basic Features screen.
Copy Basic Features Screen
4
Press <Finishing>.
5
Press <Staple + Collate> or <Staple + Group>
<Next>.
6
Select how to staple.
To staple in one location in the corner of the page, select <Corner> for the staple position.
To staple in two locations in the side of the page, select <Double> for the staple position.
To staple in the section where the paper is folded in half, select <Saddle Stitch>. Depending on the option, you can attach a cover or change the folding position. When trimming the edges of the output sheets, you can adjust the trimming position.
Depending on the option, you can bind the paper by crimping without using staples. Select <Staple-Free> and specify the binding position. This is convenient for when you want to save staples or temporarily bind the paper, as you can easily tear off the paper by rubbing the crimped part.
7
Press <OK>
<Close>.
8
Press
Copying starts.
Depending on finishing functions, the installation of optional devices is needed. Optional Equipment
Depending on the paper type, you cannot use finishing functions. Specifications
