Optional Equipment
By combining options, you can use functions more efficiently.
When the Staple Finisher-V1/Booklet Finisher-V1 is installed
Booklet Finisher-V1
You can perform collating, grouping, stapling (Corner/Double/Booklet), and saddle folding with this option. In addition, you can manually bind with the stapler or bind without the stapler.
Staple Finisher-V1/Booklet Finisher-V1/2/3 Hole Puncher Unit-A1/2/4 Hole Puncher Unit-A1
Upright Control Panel-E1
If you install "Upright Control Panel-E1," you can adjust the position and angle so as to easily see the touch panel display.
Control Panel
POD Deck Lite-C1
If you install the "POD Deck Lite-C1" to the machine, you have an additional large-capacity paper deck.
POD Deck Lite-C1/Paper Deck Unit-E1
Document Insertion / Folding Unit-J1
If you install the "Document Insertion / Folding Unit-J1" in the "Staple Finisher-V1" or "Booklet Finisher-V1," you can fold output paper, and paper different from the original paper can be fed as a cover or insert pages.
Staple Cartridge-Y1(booklet unit needle case)
This option is a staple cartridge for the booklet unit which can be installed in the "Booklet Finisher-V1."
Staples for Replacement
If you install the "2/3 Hole Puncher Unit-A1" or "2/4 Hole Puncher Unit-A1" in the "Staple Finisher-V1" or "Booklet Finisher-V1," you can punch holes in your printouts.
Staple Cartridge-X1(Staple Unit staple cartridge)
This option is a staple cartridge for the Staple Unit which can be installed in the "Staple Finisher-V1" and "Booklet Finisher-V1."
Staple Finisher-V1
You can perform collating, grouping, and stapling (Corner/Double) with this option. In addition, you can manually bind with the stapler or bind without the stapler.
Document Insertion Unit-P1
If you install the "Document Insertion Unit-P1" in the "Staple Finisher-V1" or "Booklet Finisher-V1," paper different from the original paper can be fed as a cover or insert pages.
Printer Cover-H1
Install this option if you use the machine as a printer.
Printer Cover-H1
When Other Options are Installed
Control Panel
Copy Card Reader-F1
You can implement Department ID Management using the card reader.
Copy Card Reader-F1
Paper Deck Unit-E1
If you install the "Paper Deck Unit-E1" to the machine, you have an additional large-capacity paper deck.
Utility Tray-B1
This option provides space for placing documents.
Tab Feeding Attachment Kit-B1
Attach the "Tab Feeding Attachment Kit-B1" to load tab paper into the paper drawers of the machine. This option can only be attached to the Paper Drawer 3 or 4, and holds only A4 tab paper.
Copy Tray-R1
Install to use finish functions such as Collate, Group, and Rotate 90 Degrees.
Copy Tray-R1
For information on the combination of options that can be installed on the machine, contact your local authorized Canon dealer.
