Finishing by Collating/Grouping
When copying two copies or more from the feeder, you can select collating or grouping for the order of printouts. Select "Collate" to print in sequential page order. Select "Group" to print bundles of each page, as in 10 sheets for the first page, 10 sheets for the second page, and so forth.
1
Place the original. Placing Documents
2
Press <Copy> on the Main Menu. <Main Menu> Screen
3
Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
4
Press <Finishing>.
5
Press <Collate (Page Order)> or <Group (Same Pages)>.
6
Set <Offset> as necessary.
If you do not want to use offset (a function to shift the paper output position), press .
If you selected <Collate (Page Order)>, specify how many copies to be printed in each position using the numeric keys.
7
Press <OK>  <Close>.
8
Press .
Copying starts.
Depending on finishing functions, the installation of optional devices is needed. Optional Equipment
Depending on the paper type, you cannot use finishing functions. Specifications
When placing an original on the platen glass
Pressing <Options>  <Job Build> on the Copy Basic Features screen enables you to use the Collate/Group function even if the original is placed on the platen glass.
Insert a job separator between each page during a group output
If you select <Group (Same Pages)>, you can insert a job separator between each group. For more information, see <Job Separator Between Groups>. <Copy>  <Job Separator Between Groups>
13WR-046
