<Copy>
This section describes how to specify the copy settings.
<Register/Edit Favorite Settings>
<Function Settings>
<Copy>
You can register a combination of settings frequently used when copying to a single button. You can also assign a name to the button.
Registering a Combination of Frequently Used Functions
<Change Default Settings>
<Function Settings>
<Copy>
You can change the settings registered as default for the <Copy> function.
<Register Options Shortcuts>
<Function Settings>
<Copy>
You can register modes in the shortcut keys displayed on the Copy screen. This feature is useful when you want to register frequently used functions.
<Auto Collate>
<Function Settings>
<Copy>
If this setting is set to <On>, the machine can automatically switch between <Collate (Page Order)> and <Offset> for the finishing mode when originals are placed in the feeder. This is useful when making multiple sets of copies, because you do not need to remember to select the Finishing mode.
If a finisher is attached, <Collate (Page Order)> and <Offset> are set. However, if no finisher is attached, only <Collate (Page Order)> is set.
<Image Orientation Priority>
<Function Settings>
<Copy>
If Image Orientation Priority is set to <On>, the machine always copies an image in the same orientation as the original image. This is because the images on originals may be copied upside down, depending on the copy mode set.
<Auto Recognize Original Orientation>
<Function Settings>
<Copy>
If you set this setting to <On>, even if the orientation of the original you placed differs from the orientation set in the feeder, the image is rotated 90 degrees and copied according to the orientation of the original.
If you are enlarging A4 or A5 originals onto A3 copy paper, Auto Orientation is not performed even if it is set to <On>.
Only the images of standard size originals up to A4 size can be rotated when the copy ratio is set to 100%.
<Photo Printout Mode>
<Function Settings>
<Copy>
You can enable the Printed Image mode. If this mode is set to <On>, you can select <Printed Image> or <Photo Printout> for the image quality when copying.
<Register Remote Device for Cascade Copy>
<Function Settings>
<Copy>
You can register a printer for cascade copying, and check the information for and delete registered printers.
Copying with Two Canon Multifunction Printers (Cascade Copy)
If <Use IPv4> in <IPv4 Settings> in <Preferences> is set to <Off>, you cannot register a cascade copy printer.
You cannot delete a cascade copy printer while cascade copying with the printer.
<Speed Priority for Copying from Feeder>
<Function Settings>
<Copy>
You can give a priority to speed over accuracy when copying from feeder.
<Job Separator Between Groups>
<Function Settings>
<Copy>
When copying two copies or more with <Group (Same Pages)> in <Finishing>, you can insert sheets between each page group. If you select <On>, select a paper source.
