Item
Description
<Use IPv4>
This section describes the IPv4 settings. Setting an IPv4 Address
Setting Value
<On>, <Off>
DeviceAdmin: No
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<IP Address Settings>
Specify the IPv4 address. Setting an IPv4 Address
Setting Value
<IP Address>: 0.0.0.0
<Subnet Mask>: 0.0.0.0 <Gateway Address>: 0.0.0.0 <DHCP>: <On>, <Off> <Auto IP>: <On>, <Off> DeviceAdmin: No
<DHCP Option Settings>
Specify the optional settings for DHCP. Using a DHCP Server
Setting Value
<Acquire Host Name>: <On>, <Off>
<DNS Dynamic Update>: <On>, <Off> <Acquire DNS Server Address>: <On>, <Off> <Acquire Domain Name>: <On>, <Off> <Acquire WINS Server Address>: <On>, <Off> <Acquire SMTP Server Address>: <On>, <Off> <Acquire POP Server Address>: <On>, <Off> DeviceAdmin: No
<PING Command>
Select to check that the machine is connected to a computer over a network. Setting an IPv4 Address
Setting Value
Enter the IP address of the testing address, and press <Start>.
DeviceAdmin: No
NetworkAdmin: Yes Can be set in the Remote UI: No Device Information Distribution Available: No |
