      0WR7-0EK
      <Network>
      This section describes the network settings.
      Item
      Description
      <Output Report>
      You can print network settings list.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Confirm Network Connection Setting Changes>
      You can lock the <Network Settings>, to prevent unconcidered change the setting.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      Device Information Distribution Available: Yes
      Set TCP/IP settings of the machine.
      <Use Mopria>
      Specify whether to print data directly from mobile devices such as smartphones and tablets.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <AppleTalk Settings>
      Specify whether to use AppleTalk. Also, specify the protocol when you use AppleTalk.
      Setting Value
      <Use AppleTalk>: <On>, <Off>
      <Phase>: <Phase 2> (fixed)
      <Service Name>: Enter the service name.
      <Zone>: Enter the zone that service is registered.
      <Print Mode>: <Both>, <Spool>, <Direct>
      DeviceAdmin: No
      NetworkAdmin: Yes
      Device Information Distribution Available: <Use AppleTalk> only
      <SNMP Settings>
      Specify the SNMP settings. Monitoring and Controlling via SNMP
      Setting Value
      <Use SNMPv1>: <On>, <Off>, <Set Dedicated Community> (→), <Set Community Name 1> (→), <Set Community Name 2> (→)
      <Use SNMPv3>: <On>, <Off>, <Administrator Settings> (→), User settings (→), Context Settings (→)
      <Retrieve Printer Mngt. Information from Host>: <On>, <Off>
      <Reject SNMP Packets While in Sleep Mode>: <On>, <Off>
      <Dedicated Community>: <On>, <Off>
      <MIB Access Permission>: <Read/Write>, <Read Only>
      <Community Name 1>: <On>, <Off>
      <Community Name>: Enter the community name (public)
      <Community Name 2>: <On>, <Off>
      <Community Name> : Enter the community name (public2)
      <Use Administrator>: <On>, <Off>
      <Encryption Password>: Enter the password
      <Use Same Password as for Authentication>: <On>, <Off>
      <User Settings> : <User On/Off>, <Register> (→), <Details/Edit> (→), <Delete>
      <Register>, <Details/Edit>
      <User Name>: Enter the user name.
      <Security Settings>: <Auth. Yes/Encrypt. Yes>, <Auth. Yes/Encrypt. No>, <Auth. No/Encrypt. No>
      <Authentication Algorithm>: <MD5>, <SHA1>
      <Authentication Password>: Enter the authentication password.
      <Encryption Algorithm>: <DES>, <AES>
      <Context Settings>
      <Register>: Enter the context name
      <Edit>
      <Delete>
      DeviceAdmin: No
      NetworkAdmin: Yes
      Device Information Distribution Available: <Use SNMPv1> and <Retrieve Printer Mngt. Information from Host> only
      <Format Host Resources MIB to RFC2790>
      Specify whether the host rerources MIB is compliant to the specifications of RFC2790.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
      <Dedicated Port Settings>
      Specify whether to configure/refer to detailed information of the machine from the Canon drivers or utility software.
      Setting Value
      <On>, <Off>
      NOTE:
      If the setting is set to <Off>, some application that uses dedicated port may not be used.
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Dedicated Port Authentication Method>
      Specify the authentication method for the dedicated port.
      Setting Value
      <Mode 1>, <Mode 2>
      NOTE:
      If the setting is set to <Mode 2>, the connection of the dedicated port uses secure mode. Some application that does not support the secure connection may not be used.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Use Spool Function>
      Specify whether to spool print jobs that are sent to the machine in the hard disk of the machine.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Waiting Time for Connection at Startup>
      Specify the waiting time for connecting to a network from when the machine starts. Setting the Wait Time When Connecting to a Network
      Setting Value
      0 to 300 (sec.)
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Ethernet Driver Settings>
      Specify the Ethernet driver settings. Making Ethernet Settings
      Setting Value
      <Auto Detect>: <On>, <Off>
      <Communication Mode>: <Half Duplex>, <Full Duplex>
      <Ethernet Type>: <10BASE-T>, <100BASE-TX>, <1000BASE-T>
      <Current Transmission Speed>: <---->, <10 Mbps (Half Duplex)>, <10 Mbps (Full Duplex)>, <100 Mbps (Half Duplex)>, <100 Mbps (Full Duplex)>, <1000 Mbps (Full Duplex)>
      <MAC Address>: Displays MAC address.
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Sleep Mode Priority Settings>
      Put a priority on either the speed of waking from sleep mode or saving power consumption during sleep mode.
      Setting Value
      <Exit Speed>, <Energy Saving>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <IEEE 802.1X Settings>
      Specify the settings for IEEE 802.1X.
      IMPORTANT:
      If you set <Use IEEE 802.1X> to <On>, the machine will not completely enter the Sleep mode.
      You cannot specify 'Device Signature Key' (used for key pairs for adding digital signatures to PDFs or XPSs) or 'AMS' (used for key pairs for access restrictions) as the name for the key pair.
      You can check the content of a certificate by selecting a key pair on the Key and Certificate screen, and pressing <Certificate Details>. On the Certificate Details screen, you can press <Verify Certificate> to verify the certificate.
      You can check what a key pair is being used for by selecting a key pair with 'Used' displayed for <Status> on the Key and Certificate screen, and pressing <Display Use Location>.
      You cannot set both MS-CHAPv2 and PAP simultaneously.
      Setting Value
      <Use IEEE 802.1X>: <On>, <Off>
      <Login Name>: Enter the login name.
      <Verify Authentication Server Name>: <On>, <Off>
      <Authentication Server Name>: Enter the server name.
      <Use TLS>: <On>, <Off>
      <Key and Certificate> (→)
      <Use TTLS>: <On> (→), <Off>
      <Use PEAP>: <On>, <Off>
      <Password>: Enter the password.
      <Same User Name as Login Name>: <On>, <Off>
      <Set as Default Key>
      <Certificate Details>: Displays the details of the certificate.
      <Display Use Location>: Displays the location where the certificate is used.
      <TTLS Settings (TTLS Protocol)>
      <MSCHAPv2>, <PAP>
      NOTE:
      If you set <Use TLS> to <On>, you cannot set <Use TTLS> or <Use PEAP>.
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Firewall Settings>
      You can configure firewall settings.
      <Device Position Information Settings>
      Specify the latitude and longitude of the machine.
      Setting value
      <Latitude> : Specify the latitude.
      <Longitude> : Specify the longitude.
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Store Network Packet Log>
      Specify whether to store the network packet log.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Select Wired/Wireless LAN>
      Specify whether you use Wired LAN or Wireless LAN. Selecting Wired or Wireless LAN
      Setting Value
      <Wired LAN>, <Wireless LAN>
      DeviceAdmin: No
      NetworkAdmin: Yes
      Specify the Wireless LAN settings.
      <Direct Connection>
      Specify whether to use direct connection.
      Setting Value
      <Enable> (→), <End>
      <Connected Device Information>
      <IPv4 Address>, <Device Name>
      <Direct Connection Information>
      <Connection Status>, <MAC Address>, <IPv4 Address>, <SSID>, <Authentication Key>
      DeviceAdmin: No
      NetworkAdmin: Yes
      Specify the direct connection settings.
