      0WR7-0EL
      <TCP/IP Settings>
      This section describes TCP/IP settings.
      Item
      Description
      Specify settings for using the machine in a IPv4 network.
      Specify settings for using the machine in a IPv6 network.
      Specify DNS settings for using the machine.
      <Computer Name/Workgroup Name Settings>
      Specify the NetBIOS name and workgroup name.
      Setting Value
      <Computer Name>: Enter the computer name.
      <Workgroup Name>: Enter the workgroup name.
      <Comment>: Enter the comment.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <SMB Server Settings>
      Specify the SMB server settings to open the Advanced Box to the public in a network.
      Setting Value
      <Use SMB Server>: <On>, <Off>
      <Require SMB Signature for Connection><On>, <Off>
      <Use SMB Authentication><On>, <Off>
      <Authentication Type>: <NTLMv1>, <NTLMv2>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <WINS Settings>
      Specify settings for Windows Internet Name Service (WINS), which provides a NetBIOS name for IP address resolutions in a mixed network environment of NetBIOS and TCP/IP.
      Setting Value
      <WINS Resolution>: <On>, <Off>
      <WINS Server Address>: 0.0.0.0
      DeviceAdmin: No
      NetworkAdmin: Yes
      <LPD Print Settings>
      Enable or disable LPD, a printing protocol that can be used on any hardware platform or operating system.
      Setting Value
      <On>, <Off>
      <LPD Banner Page>: <On>, <Off>
      <RX Timeout>: 1 to 5 to 60 (min.)
      DeviceAdmin: No
      NetworkAdmin: Yes
      Device Information Distribution Available: Yes
      <RAW Print Settings>
      Enable or disable RAW, a Windows specific printing protocol.
      Setting Value
      <On>, <Off>
      <Bidirectional Communication>: <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <SNTP Settings>
      Specify settings for Simple Network Time Protocol (SNTP). Making SNTP Settings
      Setting Value
      <Use SNTP>: <On>, <Off>
      <Polling Interval>: 1 to 24 to 48 (hr.)
      <NTP Server Address>: Enter the NTP server address.
      <Check NTP Server>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <FTP Print Settings>
      Enable or disable FTP Print.
      Setting Value
      <Use FTP Printing>: <On>, <Off>
      <User Name>: Enter the user name. (guest)
      <Password>: Enter the password. (7654321)
      DeviceAdmin: No
      NetworkAdmin: Yes
      Device Information Distribution Available: <Use FTP Printing> only
      <Use UTF-8 to Display Name of FTP Print Job>
      Specify whether to use UTF-8 for displaying file names when you perform FTP print.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <WSD Settings>
      Specify the WSD settings.
      Setting Value
      <Use WSD>: <On>, <Off>
      <Use WSD Browsing>: <On>, <Off>
      <Use WSD Scan Function>: <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Use FTP PASV Mode>
      Enable or disable FTP PASV mode setting. Setting the PASV Mode of FTP
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <IPP Print Settings>
      Specify the IPP print settings.
      Setting Value
      <On>, <Off>
      <Use TLS>: <On>, <Off>
      <Use Authentication>: <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      Device Information Distribution Available: <On> / <Off> for <IPP Print Settings> only
      <Multicast Discovery Settings>
      Specify the multicast discovery settings. Monitoring the Machine From Device Management Systems
      Setting Value
      <Response>: <On>, <Off>
      <Scope Name>: Enter the scope name.
      DeviceAdmin: No
      NetworkAdmin: Yes
      Device Information Distribution Available: <Scope Name> cannot be distributed
      <Use HTTP>
      Enable or disable HTTP setting.
      Setting Value
      <On>, <Off>
      NOTE:
      If you select <Off>, <IPP Print Settings> and <Remote UI> is accordingly set to <Off>.
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Use WebDAV Server>
      Specify whether to use the WebDAV server. Making WebDAV Settings
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <TLS Settings>
      You can set the currently used keys after checking the functions that use TLS encrypted communication.Configuring the Key and Certificate for TLS
      Setting Value
      <Key and Certificate> (→)
      <Key and Certificate>: <Set as Default Key>, <Certificate Details>, <Display Use Location>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Proxy Settings>
      Specify settings for the proxy.Setting a Proxy
      Setting Value
      <Use Proxy>: <On>, <Off>
      <Server Address>: Enter the proxy server address.
      <Port Number>: 1 to 80 to 65535
      <Use Proxy within Same Domain>: <On>, <Off>
      <Set Authentication> (→)
      <Use Proxy Authentication>: <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <Confirm Auth. Info. When in Auth. Management Mode>
      Specify whether the machine checks the authentication information when you print using the drivers that support Windows Vista/7.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <IPSec Settings>
      Specify the IPSec settings. Configuring the IPSec Settings
      Setting Value
      <Use IPSec>: <On>, <Off>
      <Use IPSec> sets to <On>.
      <Receive Non-Policy Packets>: <Allow>, <Reject>
      <Policy On/Off>: Enable or disable selected policy.
      <Register> (→)
      <Edit> (→)
      <Delete>: Delete the policy.
      <Raise Priority>, <Lower Priority>: Select the priority of each policy.
      <Print List>: Print setting list.
      <Register>, <Edit>
      <Policy Name>: Enter the policy name.
      <Selector Settings> (→)
      <IKE Settings> (→)
      <IPSec Network Settings> (→)
      <Selector Settings>
      <Local Address>: <All IP Addresses>, <IPv4 Address>, <IPv6 Address>, <IPv4 Manual Settings> (→), <IPv6 Manual Settings> (→)
      <Remote Address>: <All IP Addresses>, <IPv4 Address>, <IPv6 Address>, <IPv4 Manual Settings> (→), <IPv6 Manual Settings> (→)
      <Port>: <Specify by Port Number> (→), <Specify by Service Name> (→)
      <IKE Settings>
      <IKE Mode>: <Main>, <Aggressive>
      <Authentication Method>
      <Pre-Shared Key Method>: Specify the shared key from <Shared Key>.
      <Digital Sig. Method> selected : <Key and Certificate> (→
      <Authentication/Encryption Algorithm>: <Auto>, <Manual Settings> (→)
      <Validity>: Specify the time or size of the valid data.
      <PFS>: <On>, <Off>
      <Connection Mode>: <Transport>
      <Local Address: IPv4 Manual Settings>
      <Single Address>: Enter the IP address.
      <Address Range>: Enter <First Address> and <Last Address>.
      <Subnet Settings>: Enter <Address> and <Subnet Mask>.
      <Local Address: IPv6 Manual Settings>
      <Single Address>: Press <Address>, and Enter the IP Address.
      <Specify Prefix>: Enter <First Address> and specify <Prefix Length>.
      <Local Port>: Select <All Ports> or <Single Address>. When you select <Single Address>, enter the port number.
      <Remote Port>: Select <All Ports> or <Single Address>. When you select <Single Address>, enter the port number.
      Enable or disable <Service On/Off>.
      <Key and Certificate>: Select the displayed key.
      <Authentication/Encryption Algorithm: Manual Settings>
      <Authentication>: <SHA1>, <SHA2>
      <Encryption>: <3DES-CBC>, <AES-CBC>
      <DH Group>: <Group 1 (768)>, <Group 2 (1024)>, <Group 14 (2048)>, <ECDH-P256>, <ECDH-P384>
      <Authentication/Encryption Algorithm: Manual Settings>: <ESP>, <ESP (AES-GCM)>, <AH (SHA1)>
      Selecting <ESP>,
      <ESP Authentication>: <SHA1>, <NULL>
      <ESP Encryption>: <3DES-CBC>, <AES-CBC>, <NULL>
      DeviceAdmin: No
      NetworkAdmin: Yes
      <SIP Settings>
      Specify SIP settings. For information about SIP settings, see IP FAX Expansion Kit User's Guide
      <Use Network Link Scan>
      Specify whether to use Network Link Scan.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: Yes
