Item
Description
<Use IPv6>
Specify whether to use IPv6. Setting an IPv6 Address
Setting Value
<On>, <Off>
DeviceAdmin: No
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<Stateless Address Settings>
Specify the IPv6 stateless address. Setting an IPv6 Address
Setting Value
<On>, <Off>
DeviceAdmin: No
<Manual Address Settings>
Specify the IPv6 address manually. Setting an IPv6 Address
Setting Value
<Use Manual Address>: <On>, <Off> <Manual Address>: Enter the IPv6 address. <Prefix Length>: 0 to 64 to 128 <Default Router Address>: Enter the router address. DeviceAdmin: No
<Use DHCPv6>
Obtain the IPv6 address from the DHCP server. Setting an IPv6 Address
Setting Value
<On>, <Off>
DeviceAdmin: No
NetworkAdmin: Yes Can be set in the Remote UI: Yes Device Information Distribution Available: Yes |
<PING Command>
Check whether the IPv6 address is correctly specified. Setting an IPv6 Address
Setting Value
<IPv6 Address>: Enter the IPv6 address.
<Enable> <Host Name>: Enter the host name. <Enable> DeviceAdmin: Yes
NetworkAdmin: No Can be set in the Remote UI: No Device Information Distribution Available: No |
<Only Retrieve Stateful Address Prefix>
Specify whether to obtain only the former half of the stateful address from the DHCP server by using DHCPv6.
Setting Value
<On>, <Off>
DeviceAdmin: Yes
NetworkAdmin: No Can be set in the Remote UI: Yes Device Information Distribution Available: No |
<DHCP Option Settings>
Specify the optional settings for DHCP.
Setting Value
<Acquire DNS Server Address>: <On>, <Off>
<Acquire Domain Name>: <On>, <Off> DeviceAdmin: Yes
