      0WR7-0F2
      <Wireless LAN>
      Specify the wireless LAN settings.
      Item
      Description
      <Wireless LAN Settings>
      Specify the wireless LAN settings. Connecting to a Wireless LAN
      Setting Value
      <WPS Push Button Mode>
      <WPS PIN Code Mode>
      <Other (Set Manually)> (→)
      <Select Access Point> (→)
      <Enter Manually> (→)
      Select the access point and security type from the list →<OK>
      WEP authentication (→)
      WPA/WPA2-PSK encryption (→)
      <Enter Network Key (WEP)>
      <WEP Key>: Enter the WEP key.
      <Enter Network Key (PSK)>
      <PSK>: Enter the WPA/WPA2-PSK Passphrase.
      <Enter Manually>
      <SSID>: Enter SSID.
      <Security Settings>: <None>, <WEP> (→), <WPA/WPA2-PSK> (→)
      <Security Settings (WEP)>
      <IEEE 802.11 Auth.>: <Open System>, <Shared Key>
      <WEP Key 1>: Enter the WEP key.
      <WEP Key 2>: Enter the WEP key.
      <WEP Key 3>: Enter the WEP key.
      <WEP Key 4>: Enter the WEP key.
      <Security Settings (WPA/WPA2-PSK)>
      <Encryption Method>: <Auto>, <AES-CCMP>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Wireless LAN Information>
      Display the setting information of wireless LAN.
      Setting Value
      <All>: Display all SSID information.
      <Details>: Display detailed security information settings
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Power Save Mode>
      Specify whether to set the machine to the power save mode periodically, according to the singnals sent by a wireless LAN router.
      Setting Value
      <On>, <Off>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
