      0WR7-00U
      Making Ethernet Settings
      Ethernet is a standard that stipulates communication methods within a LAN. Normally, the communication system (half-duplex/full-duplex) and Ethernet type (1000BASE-T/100BASE-TX/10BASE-T) can be set automatically. You can set them separately by switching the setting to manual operation. Register the settings as necessary.
      1
      Press .
      2
      Press <Preferences>  <Network>  <Ethernet Driver Settings>.
      3
      Make Ethernet settings.
      Normally, press <On> in <Auto Detect>. The communication system and Ethernet type are detected and automatically configured.
      Making Ethernet settings manually
      1
      Press <Off> in <Auto Detect>.
      2
      Select the communication system.
       <Half Duplex>
      Carry out send/receive functions alternately. Select this when the connected router is set for half-duplex communication.
       <Full Duplex>
      Carry out send/receive functions at the same time. Select this as a general rule.
      3
      Select the Ethernet type.
      Select <10BASE-T>, <100BASE-TX>, or <1000BASE-T> in <Ethernet Type>.
      4
      Press <OK>.
      5
      Press     <Apply Set. Changes>  <Yes>.
