Top » Access Stored Files » Setting the Print Position
07SE-13S
You can set the print position for JPEG and TIFF files to the center or top left of the page when printing.
As an example, the procedure for printing files that are stored in memory media is explained in this section.
You can use this mode only when printing JPEG or TIFF files.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the location where the file you want to print is stored.
Slect the desired file → press [Print].
4.
Select the paper source → press [OK].
5.
Press [Options] → [Print Position].
To change the paper source, see "Paper Selection."
6.
Select the desired print position→ press [OK] → [Close].
[Auto]:
If a print position is specified for the image data, it is printed as specified.
If no print position is specified, the image is printed in the center.
[Always Center]:
The image is printed in the center, even if another print position is specified.
[Always Top Left]:
The image is printed in the top left corner, even if another print position is specified.
