This mode can be used only for printing a PDF or XPS file.
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
The Booklet mode cannot be set if multiple files are selected, and their record sizes are different.
The Fold and Saddle Stitch mode can be set only if the Booklet Finisher-M1 is attached.
The maximum number of sheets that can be saddle stitched at one time is 16.
If the number of sheets is 17 or more, the booklet is not saddle stitched.
11" x 17"/LGL
LTRR
Make sure to set the Booklet Tray guide to match the paper size. Setting the Booklet Tray guide incorrectly may result in a paper jam.
Saddle stitching is not performed if there is only one output sheet.
The accuracy of folds may vary, depending on the type and quantity of paper.
