Top » Access Stored Files » Arranging Files and Folders Stored on the Network » Previewing a File
Previewing a File
07SE-12S
You can preview files stored in the Advanced Box of another machine on the network.
Press [Access Stored Files] → [Network].
Select the desired storage location → select the directory where the file you want to display is stored.
Select the desired file → press [Display Image].
To preview a PDF file, the PS Printer Kit or Direct Print Kit (for PDF/XPS) is required.
To preview an XPS file, the Direct Print Kit (for PDF/XPS) is required.
To preview an encrypted PDF file, it is necessary to enter the password on the password entry screen.
To preview a PDF file with a policy, it is necessary to enter the user information on the login screen.
4.
Press [OK].
