e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
Clearing Paper Jams
Locations of Paper Jams
Main Unit
Inside the Fixing Unit
Paper Sources
Paper Drawer 1/Paper Drawer 2
Cassette Feeding Unit-AF1 (Optional)
Feeder
Staple Finisher-M1/Booklet Finisher-M1 (Optional)
Inside the Top Cover of the Finisher
Buffer Pass Unit-K1
Inside the Front Cover
Saddle Stitcher Unit
Inner Finisher-F1 (Optional)
Inner 2Way Tray-F1 (Optional)
Copy Tray-J1 (Optional)
Reducing the Frequency of Paper Jams
Clearing Staple Jams (For Optional Products)
Locations of Staple Jams
Saddle Stitcher Unit of the Booklet Finisher-M1 (Optional)
If Memory Becomes Full During Scanning
If OCR (Text Searchable) Performs Inadequately
Printer/Fax Driver Troubleshooting
Service Call Message
List of Error Messages
General
Fax
Scan and Send
Scan and Store/Access Stored Files
Quick Menu
Printer
Network/Security
MEAP
User Setting Information Management
List of Error Codes without Messages
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Problem Solving
07SE-0HS
For information on the parts of the machine in which staple jams occur and instructions on clearing staple jams, see the following.
Back to Top
