Buffer Pass Unit-K1
Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
Remove any jammed paper in the buffer pass unit.
1. Open the buffer pass unit.
2. Remove any jammed paper.
3. Close the buffer pass unit.
CAUTION
When closing the buffer pass unit, be careful not to get your fingers caught, as this may result in personal injury.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
» Problem Solving » Clearing Paper Jams » Staple Finisher-M1/Booklet Finisher-M1 (Optional) » Buffer Pass Unit-K1
07SE-0HA
