Storing Originals While Printing
07SE-113
You can scan and store an original while the machine is printing (for example while it is processing a print job, or printing from [Access Stored Files]).
As an example, the procedure for selecting memory media as the storage location is explained in this section.
Press [Close] on the screen that appears while the machine is printing.
Place your originals → press [Main Menu].
Press [Scan and Store] → [Memory Media].
4.
Select the memory media → select the destination folder → press [Scan].
5.
Specify the desired scan settings.
6.
Press
(Start).
You can change the (time-coded) assigned name after you scan the file.
