You can specify the scan size when using originals that cannot be scanned with [Auto] or when it is necessary to specify a particular size. You can also scan an 11" x 17" original with an image that extends all the way to the edges without the periphery of the original being cut off, and register specified sizes.
As an example, the procedure for selecting memory media as the storage location is explained in this section.
Press [Scan and Store] → [Memory Media].
Select the memory media → select the destination folder → press [Scan].
Press [Scan Size] → select a scan size.
If you want to scan an 11" x 17" original with an image that extends all the way to the edges without the periphery of the original being cut off, place the original on the platen glass → press [A3+].
(See "Platen Glass.")
To specify a preset scan size:
Select the scan size you want to specify from the preset scan sizes.
To select a nonstandard scan size:
Press [Free Size].
To specify a scan size by entering values:
Press [Custom].
Press [X] or [Y] → enter the scan size in inch → Press [OK].
Platen Glass
To select a registered scan size:
Press [Custom] → press [Registered Size 1] or [Registered Size 2] → Press [OK].
4.
Press [OK].
Press [Scan Size] → [Custom].
4.
Press [Register Size] → [Registered Size 1] or [Registered Size 2].
5.
Press [X] or [Y] → enter the scan size in inch.
6.
Press [OK] → [Cancel Set.] → [OK].
You cannot select [Auto] when scanning the following types of originals. Select the desired scan size.
Nonstandard size originals
Highly transparent originals, such as transparencies
Originals with an extremely dark background
Originals placed on the platen glass smaller than STMTR
Place your original on the platen glass when [Custom] is set for the scan size.
