Top » Maintenance » Operating the Limited Functions Mode
08KE-0J6
If a specific message (the service call message) appears on the display, operate the Limited Functions Mode.
When the Limited Functions Mode is set to 'On' and make the corresponding function stop its operation, the other functions may be able to perform normally.
Call your service representative before you operate the module separation switch.
E590
Cause:
The Puncher Unit-BS1 is out of order.
Remedy:
You can make copies/prints using functions other than the hole punch function by operating the Limited Functions Mode.
E530, E531, E532, E535, E537, E540, E542, E566, E567, E568, E577, E578, E57a, E57b, E57c, E583, E584
Cause:
The Staple Finisher-Q1 PRO or Booklet Finisher-Q1 PRO is out of order.
Remedy:
You can only output copies/prints by operating the Limited Functions Mode to restrict all of the functions for the finisher such as staple and collate.
E503-8004, E5a7, E5af, E5f0, E5f1, E5f2, E5f3, E5f4, E5f6, E5fa, E5fb, E5fc, E5fd, E5fe
Cause:
The saddle stitcher unit of the Booklet Finisher-Q1 PRO or the Booklet Trimmer-D1 is out of order.
Remedy:
You can make copies/prints using functions other than the saddle stitch function by operating the Limited Functions Mode.
E518, E562, E569, E56a, E56b, E56e, E518h, E562h, E569h, E56Ah, E56Bh, E56Eh
Cause:
The Paper Folding Unit-H1 is out of order.
Remedy:
You can make copies/prints without using the folding mode by operating the Limited Functions Mode.
E503h, E5A4h, E5AAh, E5A3h, E5BAh, E5BBh, E5F0h, E5F1h, E5F2h, E5F3h, E5F4h, E5F5h, E5F6h, E5F7h, E5F8h, E5F9h
Cause:
The saddle stitcher unit of the Booklet Finisher-N1 or the Inner Booklet Trimmer-A1 is out of order.
Remedy:
You can make copies/prints using functions other than the Saddle Stitch or Trim mode by operating the Limited Functions Mode.
E514h, E530h, E531h, E532h, E537h, E540h, E542h, E568h, E56Dh, E578h, E57Bh, E57Ch, E583h, E584h
Cause:
Tray A/B/C of the Staple Finisher-N1/Booklet Finisher-N1 is out of order.
Remedy:
You can make copies/prints by operating the Limited Functions Mode and fixing the tray position.
E590h, E591h, E592h, E593h
Cause:
The Puncher Unit-BF1 is out of order.
Remedy:
After setting the Limited Functions Mode to 'On', the corresponding function will be grayed out on the display, and cannot be used.
Press [Management Settings] → [Device Management] → [Limited Functions Mode].
For instructions on setting the Limited Functions Mode from the Service Call Message screen, see "Setting the Limited Functions Mode from the Service Call Message Screen."
Select the finishing mode you want to limit.
4.
Select [On] or [Off] → press [OK].
5.
Press [Close].
The Limited Functions Mode is enabled only after you restart the machine (the main power is turned OFF, and then back ON). For instructions on restarting (turning the main power OFF, and then back ON) the machine, see "Main Power and Energy Saver Key."
