Top » Maintenance » Removing Staple Waste (For Optional Products)
08KE-0J3
When the staple waste tray of the Staple Finisher-Q1 PRO/Booklet Finisher-Q1 PRO/Staple Finisher-N1/Booklet Finisher-N1 becomes full, a screen prompting you to remove the staple waste appears on the touch panel display. Follow the procedure described below to remove the staple waste.
The Staple Finisher-Q1 PRO, Booklet Finisher-Q1 PRO, Staple Finisher-N1, and Booklet Finisher-N1 are optional products.
Open the front cover of the finisher.
Below the stapler unit is the staple waste tray. Pull out the staple waste tray.
Discard the staple waste.
CAUTION
When discarding the staple waste, be careful not to touch the staple waste, as this may result in personal injury.
4.
Return the staple waste tray to its original position.
Make sure to insert the staple waste tray as far as it can go.
5.
Close the front cover of the finisher.
CAUTION
When closing the front cover of the finisher, be careful not to get your fingers caught, as this may result in personal injury.
CAUTION
4.
5.
CAUTION
