e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
Loading Paper
Loading Paper into a Paper Drawer
Adjusting a Paper Drawer to Hold a Different Paper Size
Loading Pre-Punched Paper
Loading Transparencies
Loading Tab Paper Using the Tab Feeding Attachment Kit-B1 (Optional)
Loading Paper into the Paper Deck Unit-C1/POD Deck Lite-A1 (Optional)
Loading Paper into the Document Insertion Unit-K1 (Optional)
Replacing the Stamp Cartridge (Duplex Color Image Reader Unit-G1)
Replacing the Staple Cartridge (For Optional Products)
Replacing the Staple Cartridge in the Stapler Unit (Staple Finisher-Q1 PRO/Booklet Finisher-Q1 PRO)
Replacing the Staple Cartridge in the Saddle Stitcher Unit (Booklet Finisher-Q1 PRO)
Replacing the Staple Cartridge in the Stapler Unit (Staple Finisher-N1/Booklet Finisher-N1)
Replacing the Staple Cartridge in the Saddle Stitcher Unit (Booklet Finisher-N1)
Removing Staple Waste (For Optional Products)
Removing Punch Waste (For Optional Products)
Removing Trim Waste (Inner Booklet Trimmer-A1)
Operating the Limited Functions Mode
Replacing the Toner Cartridge
Routine Cleaning
Cleaning the Platen Glass and Underside of the Feeder
Manual Feeder Cleaning
Automatic Feeder Cleaning
Wire Cleaning
Drum Cleaning
Cleaning the Touch Panel Display
Consumables
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Maintenance
08KE-0HX
This section describes how to replace the staple case and staple cartridge in the stapler unit and saddle stitcher unit.
Back to Top
