Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Auto Adjust Gradation]
Full Adjust: (Automatic after the machine prints and scans three sets of test pages): Press [Start Printing]
Quick Adjust: Press [Start]
No
No
[Correct Density]
Black Scan for Copy/Scan and Store (Mail Box), Black Scan for Send/Scan and Store (Other Than Mail Box), Color Scan for Send/Scan and Store: 9 levels each
5 levels
No
No
[Fine Adjust Zoom]
X: -1.0% to +1.0%, in 0.1% increments
Y: -1.0% to +1.0%, in 0.1% increments
X: 0%
Y: 0%
No
No
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Change Fold/Stitch Position]*1
-2.00 mm to +2.00 mm, in 0.25 mm increments
0.00 mm
No
No
[Adjust Saddle Stitch Fold Position]*1
0.00 mm
No
No
[Adjust Double Staple Width]*1
When the Staple Finisher-Q1 PRO or Booklet Finisher-Q1 PRO is attached:
4 3/4" to 5 7/8"
4 3/4"
No
No
When the Staple Finisher-N1 or Booklet Finisher-N1 is attached: 4 3/4", 5 11/16"
5 11/16"
No
No
[Finisher Puncher Switch]*1
Speed Priority, Precision Priority
No
No
[Speed/Precision Priority for Double Staple]*1
Precision Priority
No
No
[Adjust Trim Width]*1
-2.0 mm to +20.0 mm, in 0.1 mm increments
2.0 mm
No
No
[Adjust Fold Position]*1
[Adjust Z-Fold Position]
-2.0 mm to +1.5 mm, in 0.5 mm increments
0.0 mm
No
No
[Adjust C-Fold Position]
-7.0 mm to +5.0 mm, in 0.5 mm increments
-1.0 mm
No
No
[Adjust Accordion Z-Fold Position]
-1.0 mm
No
No
[Adjust Double Parallel Fold Position]
A: -2.0 mm to +5.0 mm, in 0.5 mm increments
B: 0.0 mm to +5.0 mm, in 0.5 mm increments |
A: -1.0 mm
B: 1.0 mm |
No
No
[Adjust Half Fold Position]
-2.0 mm to +2.0 mm, in 0.5 mm increments
0.0 mm
No
No
[Adjust Saddle Fold Position]
When the Booklet Finisher-Q1 PRO is attached:
-8.50mm to +8.50mm, in 0.25 mm increments
When the Booklet Finisher-N1 is attached:
0.00 mm
No
No
[Adjust Paper Deck Plates]*1
Start key
No
No
[Alignment Adjustment When Stapling]*1
-3.0 mm to +3.0 mm, in 0.1 mm increments
0.0 mm
No
No
[Finisher Tray A Alignment Adjustment]*1
0.0 mm
No
No
[Finisher Tray B Alignment Adjustment]*1
0.0 mm
No
No
[Finisher Output Priority Settings (Heavy 2,3)]*1
(See "Changing the Finisher Output Priority Settings (Heavy 2,3).") |
Productivity Priority, Alignment Priority
Alignment Priority
No
No
[Finisher Output Priority Settings (Thin)]*1
No
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Clean Feeder]*1
Start key
No
No
[Clean Wire]
Start key
No
No
[Clean Drum]
Start key
No
No
[Original Scanning Area Cleaning Method]*1
Displaying cleaning method
No
No
*1
