Double Staple Width Adjustment
08KE-074
You can adjust the double staple width.
Press
(Settings/Registration).
Press [Adjustment/Maintenance] → [Adjust Action] → [Adjust Double Staple Width].
Adjust the staple width.
If the Staple Finisher-Q1 PRO/Booklet Finisher-Q1 PRO is attached:
Press [-] or [+] to adjust the staple width.
If the Staple Finisher-N1/Booklet Finisher-N1 is attached:
Select either 4 3/4" or 5 11/16" for the staple width.
If the width of the paper is less than 10 1/8" (257 mm), the Adjust Staple Width mode is automatically set to '4 3/4" (120 mm)'.
4.
Press [OK].
