Changing the Finisher Output Priority Settings (Thin)
When Thin paper (14 lb bond to 16 lb bond (52 g/m2 to 63 g/m2)) is used, you can give a priority to productivity or alignment for the output paper.
This mode can be set when the Staple Finisher-Q1 PRO or Booklet Finisher-Q1 PRO is attached.
(See "Staple Finisher-Q1 PRO/Booklet Finisher-Q1 PRO/Puncher Unit-BS1.")
Press
(Settings/Registration).
Press [Adjustment/Maintenance] → [Adjust Action] → [Finisher Output Priority Settings (Thin)].
Select [Productivity Priority] or [Alignment Priority] → press [OK].
Details of each item are shown below:
[Productivity Priority]:
This mode gives a priority to productivity. The output paper may not be aligned.
[Alignment Priority]:
As a priority is given to aligning the output paper, the production speed decreases compared with [Productivity Priority] mode.
