Changing the Finisher Output Priority Settings (Heavy 2,3)
08KE-07E
When Heavy 2 (56 lb cover to 80 lb cover (151 g/m2 to 220 g/m2)) or Heavy 3 (82 lb cover to 140 lb index (221 g/m2 to 256 g/m2)) paper is used, you can give a priority to productivity or alignment for the output paper.
Press
(Settings/Registration).
Press [Adjustment/Maintenance] → [Adjust Action] → [Finisher Output Priority Settings (Heavy 2,3)].
Select [Productivity Priority] or [Alignment Priority] → press [OK].
Details of each item are shown below:
[Productivity Priority]:
This mode gives a priority to productivity. The output paper may not be aligned.
[Alignment Priority]:
As a priority is given to aligning the output paper, the production speed decreases compared with [Productivity Priority] mode.
