(Settings/Registration). The settings available for operation vary according to the type of administrator. This section describes the settings in
(Settings/Registration) that each administrator can operate.
(Settings/Registration) that each administrator can operate.|
For information on the types of administrators, see "Administrator Settings."
All users can set the settings in [Adjustment/Maintenance] (Settings/Registration).
: Only the administrator can change the settings.|
System Manager/System Administrator (Administrator)
Network Administrator (NetworkAdmin)
Device Administrator (DeviceAdmin)
[Restart Device]
[Paper Settings]
Paper Type Management Settings
[Timer/Energy Settings]
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Restrict Auto Reset Time
[Network Settings]
TCP/IP Settings
IP Address Settings (IPv4)
IP Address Settings (IPv6)
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
WSD Settings
FTP PASV Mode
IPP Print Settings
Multicast Discovery Settings
HTTP Settings
SSL Settings
Proxy Settings
Department ID PIN Confirmation Settings
IPSec Settings
NetWare Settings
SNMP Settings
Dedicated Port Settings
Spooler
Startup Time Settings
Ethernet Driver Settings
IEEE 802.1X Settings
Firewall Settings
IPv4 Address Filter
IPv6 Address Filter
MAC Address Filter
IP Address Block Log
[External Interface]
USB Settings
[Volume Settings]
Alarm Volume/Monitor Volume
Audible Tones
[Common Settings]
Paper Feed Settings
Paper Output Settings
Print Settings
Generate File
[Printer]
Restrict Printer Jobs
PDL Selection (Plug-n-Play)
[Send]
Common Settings
Confirm SSL Certificate for WebDAV TX
TX Report/Communication Management Report
TX Report - Attach TX Image to Report
Network Settings - E-Mail/I-Fax Settings
Confirm SSL Certificate for SMTP TX
Confirm SSL Certificate for POP RX
Communications Settings - E-Mail/I-Fax Settings
Limit New Destination
Only Send E-Mail to Myself
Only Send File to Personal Folder
Personal Folder Specification Method
TX Settings - Fax Settings
Fax TX Report/Fax Activity Report
Fax TX Report - Attach TX Image to Report
Set Line
Communications Settings-Fax Settings
Confirm Entered Fax Number
Allow Fax Driver TX
[Receive/Forward]
Common Settings
Divided Data RX Timeout/Always Send Notice for RX Errors
Forwarding Settings
Memory Lock Settings
Fax Settings-RX Settings
RX Start Speed/RX Password
[Store/Access Files]
Network Settings
Protocol for External Reference
SSL Certificate Confirmation Settings for Network Access
Memory Media Settings
[Secure Print]
[Address Book PIN]
[Manage Address Book Access Numbers]
[Address Book Export Settings]
[Register LDAP Server]
[Register/Edit LDAP Search]
[Acquire Remote Address Book]
[User Management]
System Manager/Contact Person Information Settings
Department ID Management
[Device Management]
Device Information Settings
Limit Functions When Security Key is Off
Certificate Settings
Key and Certificate Settings
CA Certificate Settings
Certificate Revocation List (CRL) Settings
Display Job Status Before Authentication
Display Log
Audit Log Retrieval
Key Operation Log Store Settings
Export/Clear Audit Log
Encryption Method Settings
[License/Other]
Message Board/Support Link
Remote UI Settings
MEAP Settings
Register/Update Software
[Data Management]
Hard Disk Data Complete Deletion
Import/Export All
Import
Export
Import/Export Results
Import/Export Individually
Address Lists
Device Settings (Forwarding Settings, Address Book, Send Function Favorite Settings)
Web Access Favorites
Printer Settings
Paper Information
