In case C, the Import All function may not be enabled according to the model for importing. For more information, contact your local authorized Canon dealer.
In the following cases, even if you use the Import All function, the settings information may not be imported, or the value may be changed into the closest value.
There are no optional products or functions that use the set value.
The set value is not valid.
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Settings
Register Custom Size
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Display Fax Function
Store Location Display Settings
Language/Keyboard Switch On/Off
Use Keyboard Shift Lock Feature
Display Remaining Paper Message
No. of Copies/Job Duration Status
Display Original Scanning Cleaning Area
Paper Type Selection Screen Priority
mm/Inch Entry Switch
ID/User Name Display On/Off
Setting Information
Case A
Case B
Case C
Preferences
Timer/Energy Settings
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Auto Reset Time
Restrict Auto Reset Time
Function After Auto Reset
Auto Sleep Time
Sleep Mode Energy Use
Auto Sleep Weekly Timer
Sleep Mode Exit Time Settings
Setting Information
Case A
Case B
Case C
Preferences
Network
Confirm Network Connection Set. Changes
TCP/IP Settings
IPv4 Settings
Use IPv4
IP Address Settings
IP Address
Subnet Mask
Gateway Address
DHCP Option Settings
IPv6 Settings
Use IPv6
Stateless Address Settings
Manual Address Settings
Use DHCPv6
DNS Settings
DNS Server Address Settings
DNS Host/Domain Name Settings
DNS Dynamic Update Settings
mDNS SettingsUse mDNS/mDNS Name
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
WSD Settings
Use FTP PASV Mode
Multicast Discovery Settings
Use HTTP
Proxy Settings
NetWare Settings
SNMP Settings
Dedicated Port Settings
Use Spool Function
Startup Settings
Ethernet Driver Settings
Firewall Settings
Setting Information
Case A
Case B
Case C
Preferences
External Interface
USB Settings
Accessibility
Key Repetition Settings
Reversed Display (Color)
Adjustment/Maintenance
Adjust Image Quality
Correct Density
Fine Adjust Zoom
Setting Information
Case A
Case B
Case C
Function Settings
Common
Paper Feed Settings
Print Settings
Output Report Default Settings
Register Characters for Page No./Watermark
Secure Watermark
Forced Secure Watermark
Printer Driver Secure Watermark
Adjust Background/Character Contrast
Relative Contrast
Standard Value Set.
Latent Area Density
Scan Settings
Streak Prevention
Color Scan Speed/Image Quality Priority
Remote Scan Gamma Value
Auto Online
Auto Offline
Generate File
High Compression Image Quality Level
OCR (Text Searchable) Settings
Trace & Smooth Settings
OOXML Settings
Specify Minimum PDF Version
Format PDF to PDF/A
Optimize PDF for Web
256-bit AES Settings for Encrypted PDF
Rights Management Server Settings
Set Authentication Method
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Auto Collate
Send
Common Settings
E-Mail/I-Fax Settings
Fax Settings
Receive/Forward
Common Settings
Fax Settings
Store/Access Files
Network Settings
Memory Media Settings
Secure Print
Simple Authentication Settings
Only Allow Encrypted Print Jobs
Setting Information
Case A
Case B
Case C
Set Destination
Change Default Display of Address Book
Address Book PIN
Manage Address Book Access Numbers
Include Pswd. When Exporting Address Book
Register LDAP Server
Auto Search When Using LDAP Server
Register/Edit LDAP Search Conditions
Acquire Remote Address Book
Acquire Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Setting Information
Case A
Case B
Case C
Management Settings
Device Management
Device Information Settings
Device Information Delivery Settings
Register Destinations
Set Auto Delivery
Restrict Receiving Device Information
Restrict Receiving for Each Function
Report Settings
Display Job Status Before Authentication
Display Log
Format Encryption Method to FIPS 140-2
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Memory RX Inbox PIN
Setting Information
Case A
Case B
Case C
Management Settings
User Management
System Manager/Contact Person Information Settings
Department ID Management
Register PIN
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Register/Edit Favorite Settings
Change Default Settings
Register Options Shortcuts
Send
Common Settings
Fax Settings
Store/Access Files
Common Settings
Setting Information
Case A
Case B
Case C
Set Destination
Rename Address List
Register One-Touch
Setting Information
Case A
Case B
Case C
Main Menu Settings
Setting File
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Common Settings
Setting Information
Case A
Case B
Case C
Quick Menu Settings
Button File
Setting Information
Case A
Case B
Case C
Workflow Composer
Flow Data File
Operation Setting File
MEAP User Setting Information
Data
MEAP Application Setting Information
Data
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Type Management Settings
Setting Information
Case A
Case B
Case C
Web Access Settings*
Favorites
Settings
