      0SU0-05W
      Saving Toner
      You can specify whether to conserve the amount of toner used for printing reports and lists.
      When this setting is enabled, fine lines and portions with lighter print density may become blurred.
      For instructions on how to conserve the amount of toner when printing with the printer driver, see Printing with Toner Save Setting.
        <Adjustment/Maintenance>    <Toner Saver Mode>    Select <On>
      <Off>
      Does not conserve the amount of toner.
      <On>
      Conserves the amount of toner.
