      0SU0-05F
      Transfer Roller
      When the transfer roller inside the machine becomes dirty, print quality may deteriorate or dots may appear on printouts. If this happens, follow the procedure below to clean the transfer roller. Note that you cannot clean the transfer roller when the machine has documents waiting to be printed.
      1
      Press .
      2
      Use / to select <Adjustment/Maintenance>, and press .
      3
      Select <Clean Transfer Roller>, and press .
      4
      Press .
      Cleaning starts. When the <Finished.> message is displayed approximately 40 seconds later, press to return to the main screen.
